+ Reply to Thread
Results 1 to 22 of 22
Thread: Toledo has weaker mem controller than Manchester
    Xtreme Addict ben805's Avatar
    Feb 2005
    USA
    0
    Unhappy Toledo has weaker mem controller than Manchester
    And Why is that? I just bought a X2 4400 to play with, at the exact same clock speed and settings (10 x290, 290 @3-3-3-8) for whatever reason the memtest reported the 4400's memory bandwidth about 600 MB/s less than both the X2 3800 and X2 4200 that I have, with the extra 1MB cache I would think the memory bandwidth would blow the Manchester out of the water, the 4400 also score worst in Everest and Sandra than 3800 and 4200 as well, and the worst part is....this POS 4400 can't clock any higher than either one of the Manchester and generated crap loads of heat!! man I'm so sick of keep buying the 'budget' cpu in hope to hit higher clock, in the past 2 months I'd went through TWO X2 3800, a X2 4200 and now the X2 4400.....dang it I think I better off jump on either the X2 4600 or FX-57.
    I'm running two instances of SuperPI 32M now, will try different BIOS and see if things will get better.....this sux!
    Core i7 920 D0 3844A717 4.40Ghz HT on @1.36v (LinX/Prime/3D stable), Corsair 850W, 12GB OCZ Platinum 1600, P6T Deluxe V2, EVGA GTX 285 SS, OCZ Vortex SSD 30GB x3 RAID0, HAF 932.
    Water Cooling Setup: XSPC RX360, MCP355 + XSPC Res Top, Swiftech GTZ, 1/2" Tygon, Scythe S-Flex SFF21F push, 20mm yateloon D12SL-12C pull.
    Opteron 148 CABNE 0528 GPMW 3.1Ghz @1.6v Prime Stable. Westy 37" LVM-37W3, DFI Venus 975, 2GB TeamX Cronus Micron, GSkill HZ, Sapphire X1900XTX, Zippy 700W, X-Fi Xtrememusic, 36GB Raptors x2 @Raid-0.
    WC Setup: PA120.3 +Shroud, MCP655, STORM, MCW60, 1/2" Tygon, mini res, Yate Loon.
    Xtreme Mentor Absolute_0's Avatar
    May 2005
    San Diego, California
    0
    Haha, people aren't going to believe this easily, you'll have to make a thread similar to your Venice VS San Diego shootout. I've always been a fan of 512kb cache, cheaper, cooler, seem to OC better, and about the same performance.
    Anyway, you should document this better with some screenshots. Maybe your 4400+ just has a crappy controller and your other X2s are normal.
    Intel Rig
    2500K @ 4.8 Ghz 1.304v | ASRock Z68 Extreme3 Gen3| 2x4Gb Ripjaws DDR3-2133 | Radeon 7970 @ 1250/1800 | Corsair HX850 PSU
    Custom Water of course
    Feb 2005
    USA
    0
    I'm not going to do another shootout like I did with the Venice vs SD that's for sure LOL there's always naysayer out there and they can believe in whatever they want, this is the second time I fell into this '1MB cache is superior to 512K' hype....be it single core or dual core, there's definitely no 3rd time a charm for sure All I know is...two time being a sucker is enough to stop all those doubts in my mind, back to this POS 4400 I got...if it can clock slightly higher than all my other Manchester then I wouldn't mind too much about the memory bandwidth lost but hot damn....clock worst plus the extra heat it puts out? do I have the suckiest luck! this sucker is going straight to ebay.....now I have to decide if I'm going for the X2 4600 or FX-57, arrgghhh!!
    May 2005
    0
    pick up a week 27 3800+, they seem to clock pretty good
    Intel Rig
    Xtreme Guru IvanAndreevich's Avatar
    Dec 2003
    Vancouver, Canada
    0
    Absolute_0
    Chips with 512KB L2 cache do not run cooler than chips with 1024KB L2. Cache doesn't contribute to the heat dissipation
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    Phenom™
    Sep 2002
    0
    There's a reason why I chose to test the 4600's as opposed to the 4400's Larger l2 cache makes OC more difficult.
    Moderator Major's Avatar
    Jan 2003
    Huntsville, AL
    0
    My X2 4600+ had a MUCH better memory controller than the 4400+ I have. Not sure why ? you would think it would be the other way around.
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
    Phenom™
    Sep 2002
    0
    Quote Originally Posted by Major
    That should be expected Now if it had a better memory controller than say a 4800, then there's something wrong. BTW, the 4600+ I sold OPB has literally the stongest memory controller I've EVER seen on an x2. Nothing I've seen can even come close.....
    Feb 2005
    USA
    0
    ok...atleast I now know it wasn't just my imagination regarding the weaker memory controller of my 4400 the stepping I got is:
    ADA4400DAA6CD
    CCBWE 0532 TPMW
    It kinda sucks that I can't even prime at 2.85Ghz under a single stage so I decided to yank out the IHS, the core is much bigger than both 3800 and 4200, looking at the core prints on both side it appears the contact was pretty lousy. So far I've dropped about 10'C but it's still running hotter than all my Manchesters, still running two instances of SuperPI 32M at the moment and the evaporator is at -33'C(uei DT200) and Smartguardian reports cpu at 253'C, I'll have to see how high can I prime it and if it can't do atleast 2.90G then I'll get the 4600 next, 1MB L2 can kiss my arse...
    Have you ever try to run your 4400 under the LS? how high could it prime?
    Feb 2005
    USA
    0
    Man....this shiat is sad, I'm running 20Mhz higher on the 4400 and the SuperPI 32M still can't compare to my cheap'o 3800
    3 days ago: X2 3800 @2.90Ghz
    Now: X2 4400 @2.92Ghz
    20 Mhz higher, but 30Sec slower....arrgghhh
    Xtreme Addict Perc's Avatar
    Apr 2003
    USA Tampa FLA
    0
    LOL man this is crazzy! im glad i bought the 4600x2 off of major instead of buying the 4400x2. i was within one day of buying the 4400x2 for the very same reason you did then i seen majors for sale at the same price as the 4400x2 so i grabed it and im starting to think im lucky i did. now reading your thread im damm glad i did! but then again this is just ONE 4400x2 it could be that your just unlucky with that chip who knoes well man i bid you good luck and hope you find what your looking for. nice thread man it will help alot of people in deciding what x2 not to get...
    peace perc,
    May 2005
    0
    Quote Originally Posted by IvanAndreevich
    Absolute_0
    I'm just going by what i hear. Everybody tells me that SD's hotter than Venice and Toledo is hotter than Manchester. And Ben805's experience only strengthens the theory.
    Intel Rig
    Admin Vapor's Avatar
    Feb 2005
    Ann Arbor, MI
    1
    It would make sense that there is a higher heat output of 1MB L2 chips....there're more transistors.
    Xtreme Member 5days's Avatar
    Aug 2005
    Perth, Australia.
    0
    All you people saying 512KB caches have better Mem controllers than 1MB, then how come my Venice sucks. .
    (Yes I already know the answer, I was just having a rant )
    ___I am Xtreme... are you?
    Feb 2005
    USA
    0
    My temporary spare 3000+ Venice that I bought from Microcenter about a week ago (0533 SPWM) has excellent memory controller, no problem running 2GB Ballistix at 297 @3-3-3-8 too bad it only prime stable at 2.80Ghz under single stage, nevertheless it's a good cpu to push memory to the max
    Jan 2003
    Huntsville, AL
    0
    Quote Originally Posted by ben805
    It was prime stable at 3040mhz under the LS, but I've since made mods to the mounting I think it should have done around 3.1ghz with better contact that I have now. My 4600+ did 3180mhz prime/pi32 stable with the improved contact.
    Jan 2003
    Huntsville, AL
    0
    Quote Originally Posted by s7e9h3n
    what I was saying is I would have thought the Toledo core would have had a beter memory controller vs the Manchester. That seems to be the way things go with single cores San Diego vs Veince
  18. #18
    Xtreme Addict mongoled's Avatar
    Jan 2003
    Ayia Napa, Cyprus
    1
    Quote Originally Posted by Vapor
    This is wht I like to see, some BASIC LOGIC applied to a simple situation.
    Lets see .......are
    two identical cars heavier than 1 car (YES)
    two identical buckets of water heavier than 1 bucket of water (YES)
    two fit twin sisters in bed with me better than 1 sister (Hell YES!!)
    so why cant peeps apply these simple idea to other things
    YES, 1mb cache IS going to produce more heat than 512kb cache
    doh (insert homer icon here)
    mong
    24/7 Settings
    SeaSonic X750 Gold 750W
    Asus Crosshair V
    FX-8350 1244PGT | 5.0 Ghz | 1.55v | 1.20v | LLC UH 140%
    GSkill RipjawsX F3-17000CL9D-8GBXLD
    313 x 16 | HTT 2504mhz | CPUNB 2504mhz | 2086mhz @ 9-12-9-29-50
    Asus EAH5450 512MB
    2 x Samsung 840 Pro's 128GB RAID 0
    XSPC Raystorm | EK Full Motherboard Block | 1/2" ID
    Swiftech D5 MCP655 | EK-D5 X-TOP Rev.2
    Thermochill PA120.3 | 6 x 1850rpm Scythe GT @ 5v
    EK-Multioption Advanced Res 400
  19. #19
    Feb 2005
    USA
    0
    diammn....you've got a very nice 4400, lucky you!! this POS I got won't even prime at 2.88 left alone 3.0Ghz core 1 error out much quicker than core 0 even with the IHS off. For now I'm running it at 2.80 till I get a replacement...sigh. I really don't understand how and why some people insist to fool themselves into thinking running these 4400 or 4800 at 2.80Ghz = TWO FX-57
    By the way Major, how do you like your FX-57 vs the 4600 you had? I'm still trying to decide which one to jump on....I'm leaning toward the FX
  20. #20
    Phenom™
    Sep 2002
    0
    All this talk of the 4600's makes me miss my two gems:
    OPB's 4600 (which I've had at 3300 @ 1.488Vcore) and of course is THE 10K PcMark04 cpu
    MikeGuava's 4600 - which was atop PCMark05 for quite awhile - not sure if it still is
  21. #21
    Xtreme Mentor situman's Avatar
    Jul 2004
    Brooklyn, NY
    0
    ADA4400DAA6CD
    CCBWE 0532 TPMW
    well there's ur problem. A week 32 chip. My week 29 TPMW 3800+ kicks ass. Not as good as some, but better than many.
    Asus Rampage Formula X48
    Intel Q9650 @ 4.33GHZ
    OCZ Platinum DDR2-800
    Palit 4870x2
    Creative Xi-Fi Extreme Music
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
  22. #22
    Xtreme Enthusiast sauria's Avatar
    Apr 2003
    North America, USA, TX
    0
    I have a week 29 3800+ X2 E6 that runs 2.7GHz at stock vcore on air.
    Old Standby:
    DFI LANPARTY nF4 Ultra-D (R.AD0) 623-3 BIOS
    AMD Athlon 64 3800+ X2 (CCBWE 0529SPMW)
    THERMALRIGHT XP-90 w/Panaflo FBA09A12H-1AZ 90mm (56.8cfm) - AS Ceramique
    MSI NX6600GT-TD128E GF 6600 GT PCI-E
    WD Raptor 74G Boot, WD 1200JB IDE
    NEC ND-3520AW Black
    OCZ OCZ600ADJ ATX 600W
    ALPS Black 1.44MB 3.5" Internal Floppy Drive Model DF354H121F
    Lian Li PC-60USB B2 Silver Aluminum ATX Mid Tower Computer Case
    Win XP Pro (32-bit) SP2
+ Reply to Thread
