Well, I have made a TEC cooled unit, and I thought i'd just post it up here and see what people think.
It is currently cooling an fx-57 and two 7800GTX
Here's a picture of the water cooling gear and the power supplies for the cooling
d5 pumps, BIX3 rads, 3 panaflo ultra high speed fans. I decided to do separate cooling loops for gpu and cpu.
meanwell se-600-12 and s-320-12 to power 12V cpu and 24V gpu peltiers, 226W for cpu (not enough) and 172W for gpus(~15C loaded)
Did a quick fit check, and it is a tight fit on an a8n sli premium for the graphics blocks
Started to build it to leak test
It looks something like this now:
The Fx-57 is a new addition so I'm still playing with it all.
I know its a mess, but that's what I get for shoving it all into a case!
I'll probably be ordering a Chilly1 unit rather than upsizing the cpu pelt, but I am pretty satisfied w/ the performance on the grafx =D
Oops almost forgot my favorite pic!
In the Dark:
