Results 1 to 3 of 3
Thread: DFI-NF4 and SATA 300mbps prob
    Jul 2004
    London
    i have a problem with enabling 300 mbps sata on my western digital 160gb drive. i know both the motherboard and HD support this feature.
    anandtech refers to this feature tool in order to enable 300mbps sata on this very drive:
    here
    but in my case it says that my drive doesnt support it. so can anyone help, or has had this problem?
    thanks in adv
    maz
    i7 920@4.34 | Rampage II GENE | 6GB OCZ Reaper 1866 | 8800GT (zzz) | Corsair AX750 | Xonar Essence ST w/ 3x LME49720 | HiFiMAN EF2 Amplifier | Shure SRH840 | EK Supreme HF | Thermochill PA 120.3 | MCP355 | XSPC Reservoir | 3/8" ID Tubing
    Phenom 9950BE @ 3400/2000 (CPU/NB) | Gigabyte MA790GP-DS4H | HD4850 | 4GB Corsair DHX @850 | Corsair TX650W | T.R.U.E Push-Pull
    E2160 @3.06 | ASUS P5K-Pro | BFG 8800GT | 4GB G.Skill @ 1040 | 600W Tt PP
    A64 3000+ @2.87 | DFI-NF4 | 7800 GTX | Patriot 1GB DDR @610 | 550W FSP
    Jun 2005
    Bancroft, ON, Canada
    Are you sure your drive is fully SATA II compliant? I bet not.. post the model number... and of course a Hitachi drive product is NOT going to work on your WD drive.....Please post your system specs including mobo
    "Foldin, Foldin, Foldin...keep those benchers foldin..." (Lyrics by Angra, Music is Rawhide)
    BOYCOTT MIR's
    Quote Originally Posted by Monkeywoman View Post
    aww an OC virgin! lose it tonight with Xtremesystems!!!
    Jul 2004
    London
    model:WD1600JS
    the anandtech website states here that this drive should support it. im kinda confused on what to do ATM. im sure the drive supports sataII.
