Results 1 to 7 of 7
Thread: Zalman or VGA Silencer GPU Cooler
    Xtreme Recruit
    Aug 2005
    Which ones better? I have a X850XT PE PCI-E
    I wanted to get the Thermalright V1 but after reading this.
    Heatsink Orientation issues:
    V-1 cooler should always be placed with the stacked fins (stock fan) on top as in a standard ATX tower case. Opposite placement (such as in a Lian-Li PC-V1000/PC-V1200 case) may result in dysfunction of heatpipes and risk damaging the GPU
    Which is my case I can't so what do you guys say? Zalman or VGA Silencer?
    DFI nForce 4 SLI-DR
    AMD 165 Opty Dual Core 2.8Ghz Air
    Thermaltake Big Typhoon w/ 120mm Panaflow
    G.Skill 2GB 3-4-4-8 @ 2.6Volts
    XFX 7800GTX (490/1300) x2 SLi
    74GB WD Raptor 10,000rpm
    OCZ GameXStream 600watt
    Nov 2004
    DK
    Had both on my old 9800Pro.
    Gained 15MHz on the core with the VF700-Cu over the Silencer.
    Variable fanspeed is also nice if you both bench, game and enjoy silence...
    Xtreme Mentor
    Aug 2005
    Boston, MA, USA
    I have both.
    I didn't like the Silencer at all. In 2D it is OK but in 3D mode it got pretty noisy. Not as noisy as the original cooling by far, but still noticable if you have a silent PC otherwise.
    Also, the Silencer didn't only block one PCI slot, it even goes slightly into the second PCI slot so that most PCI cards are bent a little.
    The VF700-Cu is pretty much perfect except that it doesn't automatically switch from high to low speed. I don't understand why Zalman doesn't just connect it to the original power connector.
    The Zalman is heavy, though, I have a label on my PC that nobody must move it while it is upright. All that copper in there will rip the mainboard right off.
    Nov 2004
    i recommend silencer
    but only OLD rev3
    BECAUSE it is cheaper, and takes less space, and fits almost any card
    http://search.ebay.com/search/search...ty=MetaEndSort
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    New silencers are way better than the old ones, just look at the contstruction
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    Feb 2005
    Ontario, Canada
    The vf700cu is excellent. It brought my 6600gt temps down from 81c load to 49-50c load. Plus it comes with ramsinks Zalman should have included the fanmate2 with it for the people that dont have a fan controller though.Ive heard alot of people complain about the silencer too.
    Jul 2004
    Belguim
    I like my silencer.
    Got one on my 6800Gt and load temps are around 60°-62°
    Card is clocked @ 410-1100 and its dead silent (silencer rev.2 )
    Maby the zalman would inprove my temps a little more but the silencer is ok for me.
    CPU: intel i5 3570K
    Board: Maximus V Formula
    RAM: G.skill 8gb 2666MHz
    Video: 2x ATI HD 5870 CrossfireX
    PSU: Corsair 850w
    Case: Antec P182
    Cooling: Prolimatech Megahalems
