I've been on air for a while. Now thinking of moving the old setup to water in hope of OC higher and MORE QUIET
So this is the old system that I'd like to play with:
Board: Abit IC7-G
CPU: 2.66ghz P4 (533FSB) 166x20 - Stetping 7 Rev C1/. Heard that this is fun for OC for the P4-B series.
RAM: 2x512MB HYNIX DT-D43 DDR400
VIDEO: ATI X800 Pro 256MB DDR3 AGP
HDD: 2 x 160gb SATA
PSU: CoolerMaster 450ACLX
please disregard about the upgrades, I just want to play with it and see how much more I can squeeze out while being the MOST quiet as I can. I already have another LGA775 setup that's good. Just want to have some fun with the old one
This is the similar picture of my case:
Back: 2x80mm upper, 1x80mm Lower (PCIs)
front: 2x80mm lower - kinda in the middle of the HDD shelf
Top: 1x120mm (can have up to 160mm) blow hole
Bottom: 1x80mm (with plenty of spaces
side: 1x80mm for the RAMs and 1x92mm for CPU
as you can see, it's VERY NOISY. I tried the nexus fan controller but shortered out due to too much current draw, so I'm deciding to move on to WC.
Rad: BlackICE Xtreme II *
Pump: Switftech MPC665 *
CPU: Swiftech Storm *
GPU: Danger Den Acetal MAZE4 - Is there anything that's better for the $$?
Black DD Fillport
ClearFlex 60 tubes
Barbed T Fitting- 1/2"
* I'm still unable to find a place that sell these for cheap - beside the swiftech parts where I might have to resort to order through them directly and the rad, I can't find any other places that have this one for under 60 bucks
I'd like cool the best while being the most quiet. I currently have two Delta 120mm fans that I can use for the Rad, but they're quiet noisy 48dB/130cfm with a HUGE Ball bearing = deadspot. Is there any other better fan that's as strong for the blackICE Xtreme 2 and more quiet?
Thanks again
Hook me up guys
Thanks a lot.
As long as I can keep my Full load tem lowest possible (close to idle)
