hey guys
i just got this...
validation
cooling is HT 101 with NB S4
1,925 vcore
i also got this
and this...with my pos mx 440
is this any good...can i do more....?
thnxs
hey guys
i just got this...
validation
1,925 vcore
i also got this
thnxs
wow,1.9v on air i a bit xtremeso u have THE cpu,just keep em cold,so try at least wather,but cascade would be great to find put highest clockbtw which stepping is cpu?
dice, huuuummmm can it do 3ghz????? it would be
AMD Opteron 146 cabye 0540fpbw @ 3.0ghz 1.5v' DFI nF4 SLI-DR 623-2' 2x512 Redline 4000 ' XFX 7900Gt ' 2xHitachi 80gb Sata II raid0 ' Ocz Powerstream 520w ' Thermalright XP120 w/sx 2 and delta 190cfm
Of course it can do 3ghz on DICE, if he can get 2.8 @ air, i think he would get 2.9/3ghz on water, maybe 3.2 on vapo or something, and i'm hopping he can get 3.3/3.4 with DICE. I know u can do it steel, as i said u before, that is a wonderfull chipOriginally Posted by Jonas
good luck with the dice runs
sure there is voltmod,i didnt try,but i get this picture on this forum
Is 2,8Ghz only screen stable?
Also what speed did you run during the SuperPI screenshot?
Nice CPU, good luck with the dryice
AMD Turion MT34 @ 250*9=2250MHz 24/7
ATI X800PRO
MSI K8NM FISR BIOS Rev 1.5 My first BIOS modification
2x80GB Maxtor drives @ RAID-0
1x160GB Seagate
Everything in a mATX case.
That speed is nuts! I ran 1.9v once on air with my locked 2600+. I could never get it above 2454MHz@2v though, I have an NF7s with lower spec watercooling. Keeps him under 50 which is good
2600 stable is still average.
Anyways, I´m quite impressed with your suicide at 2821 I think your SPi was at about 2650 - 2700, please check that info.
1.9v aint impressive on air, just suicidal, I´ve done 2v on Volcano 6cu (old school heatsink xD)
1,9V's not suicidal on air. I've ran 2,1V through my old barton 2500+ (locked and did 249*11 max) on air. Although I must admitt I was pretty scared :POriginally Posted by JuanFlaiter
I got 37sec with 240*11 1:1 so that might be correct too bad my barton was locked
steelballzz: here's something to beat -> http://upl.silentwhisper.net/uplfolders/upload6/269.jpg
Good luck
ATI X800PRO
1x160GB Seagate
