What FSB can CH-5 reach in a DFI Ultra-D
Wondering what I'll be able to run 2 sticks of Corsair XMS PC3200 C2 at in this board.
With timings of 2-2-2-7...
Any one know?
Crunching to Crush Cancer
Somebody, Stop Me!
Not sure about CH5 but you should be able to run them 24/7 at 250htt 1T 3.2-3.4V. I am still testing my BH5 and they are 24/7 stable at 260 3.4V
Have some OCZ 3500EL with 404 CH-5 that does 260mhz 2-2-2-5 1T at 3.4v. It is 2x256 though.
Well, thanks. That gives me a general idea of where I might get to ( when I have some more time! ). Running at 232 right now. These are dbl-sided 512's so I may not be able to get quite there ( 260 or so ), but we'll see. Volts won't be a problem. Just need to turn the multi down and see what it'll do when I have some more time. For now 232 x 12 will work.
I'm using these as this board may have killed my Mushkin Blk Lvl II PC3200. Was fine at 254 x 11, but truly balked once I got over 272 ( x 10 ).
Kind of made me leary of putting in the Mushkin Blk Lvl II PC3500 for a try. Then again, I could RMA them w the others if they choked/died. Just don't want to do that, really. I'll just see how the CH-5 does for the time being.
Thanks again.
Scott
Somebody, Stop Me!
- You may not post replies
- You may not edit your posts
Forum Rules
