Results 1 to 18 of 18
Thread: Swiftech MCP655 Review at Systemcooling.
    Dec 2004
    San Diego, CA
    http://www.systemcooling.com/swiftech_mcp655-01.html
    Another well done review from them. I think there's some misinformation floating about. Weren't people saying the MCP600/AquaXtreme had higher flow? This review shows otherwise (as long as you're under 10 feet of head).
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    read that a few days ago. excelent review.
    Jul 2005
    Illinois
    So Swiftech just puts there sticker on em and markets them as a MCP-655?
    Xtreme X.I.P.
    Jun 2002
    Belgium
    I guess so, just like DD sells them as the D5.
    Nice review BTW.
    Rig #1
    Gigabyte P67A-UD4 trying to figure out this POS board
    2600k @ ?????
    2x2Gb GSkill RipJaws-X 1333 (7-7-7-21)
    ATI 5850
    Coba Nitrox 750W
    Watercooled with HK 3.0 CU, Watercool GPU-X³ 5870 Nickel, PA120.3, Laing Ultra with XSPC top
    Rig #2
    DFI UT P35-T2R (0317 bios)
    E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
    2x2Gb Chaintech Apogee GT PC2-8500
    Powercolor 4870
    Corsair 520HX
    Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
    Quote Originally Posted by Movieman View Post
    I've got Supermicro boards that lasted longer than one of my marriages!
    Mar 2005
    Cologne, Germany
    Only thing missing I'd like to know is noise at 14 VDC, dunno if it's worth it replacing my PC PSU with a 13,8 Volt one for my 2 D5s.
    Aug 2004
    Los Angeles, Ca USA
    noise prolly isnt too bad i suspect even at 14v.
    beefin' it up!
    Dec 2004
    WPI
    i thought the D5 didn't overvolt? that article suggests otherwise.
    Mar 2005
    Cologne, Germany
    They don't above 14 VDC, so 12 Volts is basically undervolting if i remember correctly. Anything over 14 Volt will not bring anything.
    Aug 2004
    Los Angeles, Ca USA
    exactly.. its rated for 13.8 volts. 12volts is one of the specs its tested to run at, but 13.8 is the max it was rated to run at.
    Jul 2005
    Illinois
    If it worth it to run it at a higher voltage, can't be that much of a gain??
    Mar 2005
    Cologne, Germany
    It's only a small gain (~ +12% head pressure) as you can see from the review, but in my case i am running a secondary PSU for my external WC rig anyway, and PC PSUs have a terrible degree of effiency at low load, so why not go with a 13,8 Volt PSU straight away?
    edit: Lee answered my email, the noise increase from 12 V - 14 V is barely noticeable.
    Oct 2003
    USA /okla
    I just got my MCP-655 in and its very quiet and doesn't vibrate as much as my 1048
    very pleased
    i7 6700K @4.8 ghz
    XSPC RayStorm (very nice block)
    Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
    XFX-7970 with Swiftech Komodo nickel block
    Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
    Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
    Crossfire 30" decent monitor for IPS too bad SED tech died
    Docsis2.0 Docsis3.0
    -- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
    Apr 2004
    Socal
    overvolting will dump more heat into the loop though so its a trade off of head pressure vs heat
    ASUS Maximus VI Hero
    Intel 4770K Delidded @ 4.7GHz
    Swiftech DDC w/Petras Top
    EK Supremacy Direct to Die/MCW80 GPU
    XSPC 120.4
    2x8GB G.Skill
    MSI 6950 2GB 975/1400
    Samsung 830 2x128GB RAID0/WD 2x3TB RAID1
    Corsair 800D with AX850W PSU
    Dell U3011 30" LCD
    May 2005
    D5 has greater head than 50z and also puts out more heat than 50z, if you have large radiator then D5 is your choice and medium to small then 50z will be better choice
    Jan 2005
    i've had my mcp655 for almost a month now. its almost guaranteed you wont hear it unless you have absolutely silent fans on the radiator and elsewhere.
    but then again, im pretty deaf from high end air cooling of the past
    seriously tho, i cant hear this thing at all.
    c[_]
    Nov 2002
    Alberta, Canada
    they should mod the impeller
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
    Jul 2005
    Atlanta, GA
    Quote Originally Posted by Fairydust
    hey dust, which PSU are you using? i'm looking for a SMALL, space efficient power option as i'm running out of room. O.O and i definitely want to overvolt my D5 as i need every bit of flow i can get for that Swiffy G4
    "premature optimization is the root of all evil" - Donald Knuth
    <('_'<) <('_'^) (^'_'^) (^'_')> (>'_')> OMG ITS T3h POWER RANGERS!
  18. #18
    Mar 2005
    Cologne, Germany
    Prolly won't help you since I am on 220 Volts 50 Herz, so i will use this one. Still havn't decided if I will do it, as I have to run 12V/5V to my external rig for my fans anyway.
