Results 1 to 11 of 11
Thread: Need help to get my Gskill above ddr550
    Mar 2005
    Belgium
    My system is in my sig.
    On 9*275 2.5-3-3-7@2.8-2.9V my system won't even boot.(not even pass memtest #5)
    On 270mhz it gives a few errors in memtest but why won't they do the rated speeds?
    It says Gskill 4400Le rated at DDR550 2.5-3-3-7 but i have a hard time to get at DDR550. I took this ram so i could do DDR600 because my daily use is 9*300.
    I tried several bioses with no luck.
    Currently using the 510-2 Fix bios.
    Anyone can help me out here?
    Btw: below you see a64 settings.
    E6400@3.2GHZ | P5B deluxe |8800GTS 512MB | 2*250GB Hitachi + 500GB WD|
    Aerocool masstige | Seasonic 600W |
    MX510@450HZ | 24" LG 245WP
    Cooled by: Swiftech storm - MCP 655 - Maze4/EK vodni block - Nexxos Dual Extreme
    A64 3000+@2.9ghz // XP M 2500+@2.5ghz // XP M 2600+@2.6ghz benchable at 2.9ghz superpi 35s //
    AMD opteron 146@3GHZ CABYE APMW batch 0076
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Gskill TCCD can come in all forms and different weeks perform differently. What weeks do you have 431, 440, 504, 507 ?
    try loosening trfc from 14 to 16, 17 or 18
    play with drive/drive data strength and TREF combinations in memtest first then windows and take a read http://i4memory.com/showthread.php?t=327
    i've never had a pair of 2x512MB Gskill PC4400LE that would do 300mhz easy so it might be too much of an ask, i've had 4 pairs of 2x512MB Gskill PC4400LE (2 are rma replacements for 1st 2 pairs which didn't do stock speeds) and 2x 256MB Gskill PC4400LE which do 305-315mhz 2.5-4-3-7
    normally it's around 290mhz 2.5-3-3-7 to 294-296mhz 2.5-4-3-7
    sure i can bench at 300mhz but no where near stable in pcmark04 custom memory test http://i4memory.com/showthread.php?t=474
    Mar 2005
    Belgium
    week 431 it is.
    I tried tref 16 and Trc 12 now and seems to work for 2.5-4-4-7@300 HTT
    Mar 2005
    Belgium
    Quote Originally Posted by 187(V)URD@
    week 431 it is.
    Seems not to be stable at all. :/
    May 2005
    Did you try 623-3?? Try 275*8x to rule out the cpu crapping out on you and than run some memtest your ram should be able to do those speed and timings easy, if not its rma time
    CPU: AMD FX-57 0516
    Ram: G.Skill 1gb PC 4400 LE / 2x512 Mushkin Redline
    Video Cards: BFG 7800 GTX Viperjohn modded
    HD: 2X WD Raptors 74gb
    Sound: Sound Blaster Audigy 2 ZS
    Case/Cooling: Lian-Li PC65 - Vapochill LS
    Mobo: DFI NF4 Sli-DR
    PSU: PCP&C 510W SLI
    Mar 2005
    Belgium
    623-2 seems to be much better for me.
    I am on 294mhz 2.5-4-3-7@ 2.7V.
    After 5 bioses i finnaly got one that works for my tccd's
    May 2005
    Good to hear
    CPU: AMD FX-57 0516
    PSU: PCP&C 510W SLI
    Mar 2005
    Belgium
    the funny part is I can get 296mhz 2.5-4-3-7 stable but i can't get it 275mhz 2.5-3-3-7 stable like its rated on the box, gives me like 600 errors in one loop in memtest #5. Seems weird since it is an average LE overclock if I look around on forums.
    May 2005
    ESP/NL
    You can try in the BIOS this settings:
    Drive strenght: Level 5 or 7
    Data drive strenght: Level 2
    You could try as well:
    Idle cycle limit: 256
    Bios 623-3 gives me the higher FSB/stability.
    Mar 2005
    Belgium
    Alright I going to see if level 2 does the thing, if not I flash another bios (623-3).
    Drive strenght: Level 5 gives me less errors then 3 and 7.
    Also 623-3 is an offi bios but there is also another unoffi 623-3 bios. Which one do I need to take?
    Mar 2005
    Belgium
    seems I can't save settings with 623-3 Bios. It won't boot anymore when i change default settings.
