short q:
gigabyte 945 mobo spec's say1066mhz FSB supported
so then should i be able to raise my fsb from 800 to 1066 without any promblem concerning the mobo![]()
thnx 4 rplys![]()
short q:
thnx 4 rplys![]()
celery D 326 2.53gHz 256kb @ 3.6
4x 256mb ddr2 533MHz corsair value ram
gigabyte 8I945G mobo, bios F5
seagate 160 gig sata
gigabyte 6600gt 128mb (600/1300)
XP 64bit
you have to try,,,why not
Pc power&cooling 850w,meke's birkat cooling single stage(-40),chilly1 ln2/dice container.
Ebemin OC Team
you should be able to, worst comes to worst just reset the cmos![]()
P4 3.6ghz 660@5.2ghz max (crappy chip) | Asus P5WD2 Premium -0606- |Corsair pc5400UL | XFX 7800GTX 550/1380(water) |Audigy X-Fi | Vapochill LS | PC-65 | OCZ p.s. 520w
P-M 730@2.7 sPI | P4C800E-D | Geil One BH | X800XT 560/594 FS-V7| Zalman C77 | OCZ p.s. 420w
Your mobo will not be an issue at 1066. It is just a matter of your RAM and CPU taking it...
What the world needs is more geniuses with humility, there are so few of us left.
DS3 | E6400 - 3.2GHz | OCZ PLat. PC6400 | 6800GT | Zippy 460W
Originally Posted by aja
Set ram to 1:1 and you should be a-ok for the change as long as your cpu can run 3725mhz stable.
Only the stupidest humans believe that the dogma of relative filth is a defense.
