link for fans...
http://www.bigfootcomputers.com/Merc...y_Code=0100.41
Dangerden
Innovatek
Koolance
Swiftech
link for fans...
http://service.futuremark.com/compare?2k1=6646300
http://service.futuremark.com/compare?pcm=1361699
http://service.futuremark.com/compare?2k3=921862
2.8E/Abit IC7-G/2x512 Corsair TwinX4000-Pro/Sapphire 9800XT 256/36 WD Raptor/Logitech Z-560/Viewsonic P95F+B
do you think those fans will provide efficiant cooling? I need to know because there on sale now till the end of the week
here is a pic of my case....
and...
another picture of my baby!!
TrythemOriginally posted by #ball3r
which of these 3 kits would you get?
1) http://www.ntcw.com/Merchant2/mercha...de=HF-STH202-C
2) http://www.coolerguys.com/Merchant2/...egory_Code=WHS
3) http://www.criticool.com/9Complete%20Kits.html
I've dealt with them a couple times. bought me a MCW462-UHT and MCW-50T
ok can someone here tell me part by part exactly what i would need for my water cooler keeping in mind I want to keep it in my case, and not cut any blowholes? Please . I would like to use those 69cfm fans if they will not sacrifice my cooling (sandwich the rad with 2). I'm not interested in the Innovatek stuff any more so only Dangerden or Swiftech. I like the looks of the Swiftech blocks but was planning on using UV paint on the block anyway so if the maze3's are good those will do. I need a block for cpu, radeon 9700 pro, and my chipset. I would like to use a resovior maybe even a bayres. I would like to keep this quiet, but get my temps down really low so i can overclock my new cpu like crazy. I really appreciate the help, and look forward to a reply
*update* just purchased an Epox 8RDA+, 2x256 OCZ PC3500 EL CL2, some more glowing lime green loom, 2 120mm led fans for water cooler, and ramsinks for the radeon i'm buying. Here is the kit i'm thinking of getting, tell me what you think about it. The only thing that was left out is i'm getting a chipset block, a res, and green UV water dye.
now here it is...
Quantity Description Price TOTAL
1 Maze 3 AMD 1/2" connections - Lucite brass $68.50 $68.50
Maze 3 AMD 1/2" connections - copper brass $74.50 $-
Maze3SHD AMD 1/2" connections - Lucite brass $82.50 $-
Maze3SHD AMD 1/2" connections - copper brass $87.50 $-
Maze 3 P4 478 1/2" connections - Lucite brass $70.50 $-
Maze 3 P4 478 1/2" connections - copper brass $76.00 $-
1 GF4 / Radeon 1/2" connections - Lucite brass $73.50 $73.50
Z-chipset 1/2" connections - Lucite brass $63.50 $-
Cyclone5, Med base, 1/2" connections $105.00 $-
Eheim 1048 - 158 gal/hr $99.50 $-
1 Eheim 1250 - 316 gal/hr $118.50 $118.50
Supreme Mag 20 - 250 gal/hr $70.00 $-
Supreme Mag 30 - 350 gal/hr $80.00 $-
1 Custom CritiCool Pump Relay Kit $30.00 $30.00
Black Ico Pro EVO $77.50 $-
1 Black Ice Extreme $109.50 $109.50
1 Red Line Water Wetter 4oz $6.50 $6.50
Papst 120mm, 4312L / connectors $35.50 $-
3/8" Vinyl Tubing $0.60 $-
10 1/2" Vinyl Tubing $0.70 $7.00
1/2" ClearFlex60 Tubing $2.25 $-
Cylindrical Reservoir $50.00 $-
3/8" - Plastic Tube Clamp $0.85 $-
13 1/2" - Plastic Tube Clamp $0.85 $11.05
3/8" - Metal Tube Clamp $0.80 $-
1/2" - Metal Tube Clamp $0.80 $-
Nylon Tee 3/8" $2.75 $-
1 Nylon Tee 1/2" $2.75 $2.75
Nylon Barbed Elbow 3/8" $10.00 $-
Nylon Barbed Elbow 1/2" $10.00 $-
Plastic 3/8" valve $8.50 $-
1 Plastic 1/2" valve $9.50 $9.50
plastic 3/4" threaded to 1/2" barbed fitting $3.50 $-
brass 3/8" threaded 1/2 " barbed fitting $4.00 $-
brass 1/2" threaded to 1/2" barbed fitting $4.00 $-
brass 3/4" threaded to 1/2" barbed fitting $4.00 $-
3/8" to 1/2" Barbed adapter $4.00 $-
Artic Silver 3 $13.00 $-
1 Industrial Velcro $2.00 $2.00
Special Order
SubTotal $438.80
Shipping: Shipping & Handling $0.00
Taxes GST $30.72
TOTAL $469.52
