After reading the article below I'm wondering if we are not just waisting time and money chasing for high HTTs... Perhaps cheap DDR400 at 2-2-2-5 is just enough for A64s...
http://www.anandtech.com/cpuchipsets...oc.aspx?i=2469
Intel E8500 Q813A248; Asus Rampage X48; TRUE 120; 2x1GB Mushkin XP2-8500; EVGA 8800GTS 512MB; 2x320GB Hitachi P7K500 Raid 0; Zeus 850W; Lian Li PC-60BPlus; Samsung 226BW; Saytek Eclipse; Logitech G9
from DDR400 to DDR488 yield 5% performance difference.
VX at ~265 @ 2-2-2-6 is about TCCD/5 at 300 @ 2.5-3-3-8
So 44Mhz OC (DDR488) yield 5% increase, so 130Mhz OC (DDR530) would yield ~14.77% if it's a linear relations.
So really, if you OC to 300HTT with TCCD, you would get close to 15% performance gain. 15% is not much, but certainly can't be overlooked. (15% here, more % from CPU/GPU will give you more.)
A wiseman once said, "If Bible proves the existence of God, then comic books prove the existence of Superheros."
Lastly, good enough is never good enough.
5% performance difference would be significant if you were in the top 10 3Dmark, for the rest its just fun to get the most out of your hardware.
By that reasoning most people here shouldn't bother with cascades, phase change units, watercooling, and about 90% of the other things we do to make our computers faster. It's not like I need my computer running at 2.5ghz, I just want it there.
Eery little bit counts. I like to know that my comp is running at its fullest.
As you can see from my quick graphical illustration, the difference in performance of the TOP system and the "performance" systems is actually very little. The cost is where the real difference lies...Law of Diminishing Returns. You will note that the biggest and baddest is always the lowest "bang for the buck." But that's why this is XtremeSystem.org and not "Cost-effectivesystem.com" eheheheh.
-FCG
being a s754 guy i would have liked to have seen the impact of more bandwith in single channel setups. i'm waiting for the M2 before i build new again so maybe things will change at that time. for now though being single channel bound makes me wonder. even though this article reasures me that i can run comfortably at DDR400 w/tight timings that really is never enough. or else that would mean all these rma's i've been doing have been for naught.
XEON 3075 (3.2ghz for now)
Asus P5E
Crucial Ballistix DDR2-800 2gb (stock for now)
HD3850 512mb (715/945 for now)
OCZ Powerstream 520watt
Coolermaster CM Stacker
i may just be stupid, but i think their results are due to testing the ram on dividers. from what i've seen, running ram on anything but 1:1 lowers the efficiency. most of us want the ram that's capable of running high htt so that we can keep our ram running 1:1 with our oc'ed cpu which would allow the higher bandwith to shine a tad brighter.
opteron 170 @ 2.6ghz 1.45v | koolance pc2
asus a8n32 sli deluxe | vista ultimate 32
7900gt ko | 2x1gb mushkin 1:1 2t
perc4 w/128mb | 3 x 15k u320 raid 0
Running 1:1 means nothing on an S939. Run a search here on the board for details.Originally Posted by pRS317
"Foldin, Foldin, Foldin...keep those benchers foldin..." (Lyrics by Angra, Music is Rawhide)
BOYCOTT MIR's
Yeah, well done. It's true!Originally Posted by freecableguy
C
or on s754, because it never really is "1:1"Originally Posted by Ugly n Grey
for a quick explaination:
the memory controller runs at cpu speed, with a divider setting the ram speed. the lowest divider is 5x, so the HIGHEST ratio you can use is 1:5.. typically it'll be around 1:9-1:12 in normal overclocks
Got a fan over those memory sticks? No? Well get to it before you kill them
And by the way, normally we increase the CPU speed, too, which increases the performance gain from higher bandwidth.. Not by much, but as they said
i'll agree with all of the pro statements, what is the point of having capable components and not releasing the potential. it's all for fun and tweaking, consider the name of the forum for further referance.
mobo: strix b350f
gpu: rx580 1366/2000
cpu: ryzen 1700 @ 3.8ghz
ram: 32 gb gskill 2400 @ 3000
psu: coarsair 1kw
hdd's: samsung 500gb ssd 1tb & 3tb hdd
seeing the bling in my case and then seeing the performance to back it up.. well,... it's .... cool and refreshing... tastes great and less filling. Who cares about diminishing returns :P
ALIENS are bringing my next kentsfield based rig in a UFO case!
and considering the price u paid for the premium componentsOriginally Posted by i found nemo
Intel Core 2 Duo E6400 | Asus P5B Plus Vista Edition | OCZ PC2-8500 SLI EPP 4x1GB
XFX 8800GTS 640MB | SilverStone Strider 560W | Creative X-Fi XtremeMusic
I've been debating this as well given my recenly aquired addiction to BF2. 1GB just doesn't cut it anymore. :-(
Asus P6T-DLX V2 1104 & i7 920 @ 4116 1.32v(Windows Reported) 1.3375v (BIOS Set) 196x20(1) HT OFF
6GB OCZ Platinum DDR3 1600 3x2GB@ 7-7-7-24, 1.66v, 1568Mhz
Sapphire 5870 @ 985/1245 1.2v
X-Fi "Fatal1ty" & Klipsch ProMedia Ultra 5.1 Speaks/Beyerdynamic DT-880 Pro (2005 Model) and a mini3 amp
WD 150GB Raptor (Games) & 2x WD 640GB (System)
PC Power & Cooling 750w
Homebrew watercooling on CPU and GPU
and the best monitor ever made + a Samsung 226CW + Dell P2210 for eyefinity
Windows 7 Utimate x64
haha the "why do we do this?" question always seems to come up. As others say, it's for the fun usually. And if you're a real hardcore comp user, it feels good to be able to say that your computer is faster than most other systems in the world. For the XS world record holders, they can say faster than all other systems in the world .
No need for discussion - we need DDR600 2-2-2-5..........
Previous system:
DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
well i had 2 GB of bh5 but everytime i tried dividers the limit was ~265MHZ.
A Superpi 1m time with 280/250HTT/RAM at 2-2-2-6 1T was ~31,5s and my yesterday 280mhz run with my new ocz 3-4-3-8 2T was 280MHZ 1:1 34s ^^
So i supose i will need at least 300mhz ram clock to get my 31s again
I have a weak mem controller i guess but in 2 weeks i will have another 3200+ for testing here to see if it's really the limiting point.
But nevertheless we need strong memcontrollers first before hitting 2-2-2-5 @300mhz...
i tested my khx on 3 boards and 3 procs. the best one was hitting 255 2-2-2-5 1T on my k8nxp-9 and 3500+ so i know that my memcontroller on the 3200+ isn't that good .
Greetz SoF
| '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
| '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
| '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
| '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
| '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
| '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
| '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
| '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
Originally Posted by saaya
ok ill take a 2x1gb kit of that please oh ill take the 2.6v 1t model as wellOriginally Posted by HARDCORECLOCKER
________
E CIGARETTE SHOP
OK so afterall should we look for latency more than bandwidth?
