Hi there,
UPDATED: 7/15/05
ok this should be what I'm looking at(of the 2 choose one)...
Intel Pentium D Dual Core 820 http://www.zipzoomfly.com/jsp/Produc...e=pricegrabber
Asus P5WD2 Premium
http://www.xpcgear.com/asusp5wd2p.html
Hitachi 500GB Hard Drive
http://www.onsale.com/onsale/shop/de...sp?dpno=570411, can anyone tell me about this site?
Maybe this one, if I don't get the Hitachi
http://www.pricegrabber.com/search_g...sterid=3660409
SilverStone SST-TJ03
http://www.monarchcomputer.com/Merch...AFFIL=FRG&NR=1
Turbo-Cool 850 SSI
http://www.pcpowercooling.com/produc...hp?show=T85SSI
BFG GeForce 7800 GTX
http://accessories.us.dell.com/sna/P...furbished=&fe=
Plextor PX-716AL(Hopefully this is the one thats SATA)
http://www.pricegrabber.com/p__Plext...iter,__7731108
Also...may get a dvd-rom and was wondering if LightScribe drives are worth the money.
OCZ Technology 1GB PC2-6400 DDR2
http://www.pricegrabber.com/p__OCZ_T..._Kit,__8523605
Newegg has these, but not in a kit for about $95. Should I get the kit or get 2 sticks then run them in dual channel mode?
Creative Sound Blaster Audigy2 ZS Gamer
http://www.pricegrabber.com/search_g...sterid=1551871
Sleeving
http://xpcgear.com/carbonsleeve4.html
http://xpcgear.com/12carbonsleeve.html
http://xpcgear.com/3heatshrblk.html
Filter
http://www.frozencpu.com/ffa-01.html
or...
http://www.frozencpu.com/ffa-09.html
AS5
http://www.frozencpu.com/thr-17.html
Arctic Silver® ArctiClean
http://www.frozencpu.com/thr-19.html
C4 NGen
http://www.cshyde.com/Excess%20Inv%20Sale.htm
http://www.pricegrabber.com/search_g...sterid=3191290 ?????should I get it?????
and others...
Or everything listed above but with these changes...
AMD Athlon 64 X2 4400+
http://www.pricegrabber.com/p__AMD_A...ssor,__9157342
DFI LANPARTY UT nF4 SLI-DR
http://www.pricegrabber.com/p__DFI_L...oard,__7712977
and some other kind of ram...I think my HyperX should work.
This is just as of now...I may wait for the XFI, Ultra/Fudo, umm...other stuff
Remember now, I mostly want to make this future proof for as long as I can.
Thanks alot for all the help
As for the dual cores, unless your a programmer or a modeler, theres no real reason to invest in this... unless your super paranoid about your computer being compatible in the future, but by the time that day comes you'll be ready to build a new system. As for dual processors, theres no reason to do that unless again you're rendering models or you're a programmer, or running a server. Also, unless your needs involve a lot of media entertainment and streaming video, then don't get Pentium. They've barely put a cent into R&D since PIII and have been recycling the same technology for years, just pushing it farther and pumping more juice through it, causing it to run hotter and hotter. The dual core prescotts are gonna run so hot you can fry and egg on them. Don't give Intel your money, they'll just laugh all the way to the bank.
If you plan on constantly working on your system or upgrading it every few months or less, then get a case that’s made of steel on the interior as aluminum doesn't hold up and starts to wear down and bend. If you want something light for lanparties, then go for aluminum which is also better for conducting heat away from your components.
you have come to the best place 4 help
RaDiOaCtIvE
