I think it can work pretty well as a evap and very good too as a waterblock,very nice design
swastika?
can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
a little bit creepy, but, it would work. only problem I have would be there is a chunk of copper (center of the swastika) over the core, I prefer to have refrigerant evaporating directly over the core, not sure if it matters THAT much, but I have no way to test for sure. (maybe one of the more experienced builders can tell me I'm wrong? :P)
Hitler didn't design the swastika, so how could he have a copyright on it??
It was actually designed by the ancient Egyptians, about 3,000 years ago. Strangely, it means "good to be" or "good luck" and basically a symbol of peace.
i thought it was a hindu symbolOriginally Posted by MutantToad
it is untill you put the 90*C angles in the opposite direction.Originally Posted by blinky
In that kind of evap how thick should be the base?Is 6-8mm ok?
Originally Posted by GuGaCoSa
my friend Gloa, says 4mm, second me is little,best 8mm for me........
P5N-Tdlx 780i SLI-Q6600 G0 @3,6ghz.. liquid-2x1gb Geil Blak Dragon 900mhz 4-4-4-10-Pov 8800gt 740-1850-1050 stock cooling-Antec Tc 550Watt-Raptor 10k-2x80gb ide Raid0-500gb sata2 raid0-320gb sata II
No Gloa,Guga hehe,ill put 8mm in my next evap to see how it works
Oh my...
Racist! j/k
CPU: AMD FX-57 0516
Ram: G.Skill 1gb PC 4400 LE / 2x512 Mushkin Redline
Video Cards: BFG 7800 GTX Viperjohn modded
HD: 2X WD Raptors 74gb
Sound: Sound Blaster Audigy 2 ZS
Case/Cooling: Lian-Li PC65 - Vapochill LS
Mobo: DFI NF4 Sli-DR
PSU: PCP&C 510W SLI
Gloa is Gloatizardhow it works yours evap with 8mm cp?good?according to me the best measure
i don't understend if you are joking, i hope itOriginally Posted by waddupmm
Gloa is criminal
sorry for spam
just because it looks similar to something used by the nazi-regime it sure does not mean he's a racist.Originally Posted by waddupmm
The Swastika got a new meaning after WW2, it had good meanings but was abused.
Now if a new development in whatever would look like a Swastika should it been forbidden? I hope not...
I hope the Administrators/Moderators will remove postings like this to prevent a discussion ending in nowhere.
gloatlizard:
unless you have 2 channels you may have problems with the flow resistance, it hast to be nearly the same or the refrigerant will only flow through one channel.
dual ... quad ... hexal ... octal ... hexadecal?
j/k means joke, the poor guy was joking... leave him alone
8mm base thickness???Originally Posted by GuGaCoSa
Based on what principle people uses that gigantic base?
You need to get the heat of your proc as fast as possible, you have the IHS first, then a 8mm thick base, so your heat will never gets a path... you only get wider delta in proc/evap temps.
My next evap will be 3mm or less thickness.
Check the comparative graph in evap/proc temps in the Asetek site, you know that the promie have a much ticker base than the vapo ls, see what happend...
haha a swastika... who are you building that for? actually that is still used today I think it's on the Isle of Man's flag (an island near england). My father was a history major and he once explained that it was indeed an ancient symbol, I think it is from egyptian times.
yes, the swastika was an ancient symbol originally
no the IOM doesn't use it for it's flag - it uses 3 legs of Knights armour
anywhoo - evap design looks nicely thought out =]
yea.. need to seal off one direction imo.Originally Posted by Sidewinder
AMD Athlon 64 3700+ @ 300x10________15" Macbook Pro
2x 512mb Mushkin DDR _______________2x 1Gb DDR2
Sapphire X850XT____________________X1600M
DFI Ultra-D_________________________2.16Ghz Merom C2D
Lian-Li PC7A________________________OS X/XP
PCP&C 610w Silencer
