Results 1 to 18 of 18
Thread: 6800GT overclocks
    Jan 2003
    NYC
    6800GT overclocks
    is it more or less guarnteed that a GT will overclock to at least an ultra right out of the box?
    6800GT = 350mhz@core with 1000mhz ram
    6800Ultra = 400mhz@core with 1100mhz ram
    it seems that alot of these GTs are getting around 410~420 on air with stock coolers
    May 30th, 2007
    Quote Originally Posted by Haltech View Post
    Ive alrwady predicted that within 3 years, Sony will be purchased and liquidated.
    i7 920 D0 @ 2.8ghz // GTX 670 // Rampage II Extreme // 14GBs DDR3 // 550w PSU // corsair H100i // Corsair 800D
    i7 3770k stock // Maximus V Gene // 16GB @1600 // OCZ z850 //
    i7 3930k @ 4.5ghz // 780 SLI // P9X79-E WS // 16GB @ 1600 // AX1200i // and a horrible swiftech h220 // Carbide Air 540
    Mar 2004
    pretty much...i have only heard of one or two cards that didnt make it
    2.4C killer
    May 2003
    San Diego, CA
    my leadtek 6800GT, one that hopefully works, will be here tommorow and ill test it and let you know
    Jan 2003
    NYC
    hmm so i could just buy a 6800GT and flash it to an ultra?
    May 30th, 2007
    Nov 2003
    happy place
    i would advise against that... , the 6800 gt only has 1 molex connector compared to the 6800 ultra. you may not be able to get enough power, even with bios flash.
    my pny 6800 gt did 445/1100 max on stock cooling in aquamark3.
    --===== proud owner of new razor tarantula gaming keyboard =====--
    Oct 2004
    Wild West, USA
    Dont do that cause Ultra bios can damage your card. Gt seams to be dying alot when flashed to ultra. Insted just Vmod your GT bios. I have found that Gainward GT GLH bios score the best. Be careful flashing and have pci card ready in case you get no boot
    Abit IC7 P4 2.8a @4.21 | P4 3.4e @4.9 | Gainward 6800GT GS @486/1386
    Asus P4P800 SE Dothan 730-PM @ 2900 | EVGA 6800 Ultra GS @521/1376
    e8400@4.3G & 8800GTS G92 800/1932/1132 as gaming rig 24/7
    Custom self build chillbox with watercooling @-28c 24/7 | chilled wc " cpu -18c idle/-3c load
    3DMark 2005 Score Dothan & 6800U
    3DMark 2005 Score p4 & 6800GT
    Jun 2005
    Quote Originally Posted by b0bd0le
    Just get rivatuner and set the clocks to go to 400/1100 on startup. if you do that, it will run like an ultra anyway. No BIOS flash Needed, and you still preserve the value of your card.
    Mar 2005
    Bay Area, CA
    Those ultra memory timings are looser than the GT's, so you will just be tossing some performance away if you flash to the ultra bios.
    Apr 2005
    Just adjust the clock frecuencies at Ultra's Speed, and maybe do a Vmod to the bios card so you can gain a lot more mhz.
    2.4C killer
    May 2003
    San Diego, CA
    Ok, mine at first would only do 1.05ghz mem, but my case temp said it was 53C!! and the HSF thing for my card is freakin hot, so I took side off, trying to decide how to cool it. Now its doing 435mhz Core 1150mhzmem stable. My PSU is INCREDIBLY weak, and my comp just randomly shuts off sometimes, and the whole video card gets pretty hot. So I think it probly has more in it.
    Question, is there a way to turn up the fan speed?? It almost seems if mine isnt even working because its so slow I put my hand in front of it gaming and I dont feel a thing. Put napkin in front to see if it lifts it a bit, but barely jiggled the edge I cant really see it, its got a black filter in front of it from factory, and cant really tell lol. Dont want to take it out
    Aug 2003
    Belgique, Belga, Belgio, Belgium, Belgica, Belgie, Belgien
    Quote Originally Posted by railer
    That's BS, show me one GT that has died from flashing to an ultra.
    The only thing an ultra bios does (besides the obvious clockspeeds) is raising the vgpu to 1.4V and lowering the timings of the memory.
    .:C2D 6600 :: Tuniq tower :: Asus P5B dlx :: 2GBHZ :: OCZ 520W :: 8800GTX :.
    Aug 2005
    Colorado, USA
    This may just be a dead thread but there are pleanty of ppl out there without the $$ for a 7800 and the GT's are going for almost half the cost of them now for a card that definatly holds its own against any game.
    I personally bought gigabytes PCIe GT and started to fool around with it. With out upping the voltage OC was horrible. But after upping to 1.5 it runs stable 430/1130 on stock cooling. well i did pull off the wrap around heat sink and replaced the crappy paste with AS5 on the GPU and pipe contacts for a 6C drop upder load, which made me happy , gunna order a NV silencer 5 in another week or so. But im pulling down almost 6K on 05 and a solid 13.5K on 03 and i know im CPU limited in my rig with an A64 3000+.
    EVGA 780i SLI
    Intel Q6600 @ 3.6 on Water
    8GB Corsair DDR2-1066 5-5-5-15
    2x GTX 260 SLI + 8800GTS 640 PHYSx
    Corsair 1000W PSU
    Antec 1200
    1TB Seagate
    Xtreme 3DTeam Member
    Dec 2004
    UK
    nothing in overclocking is guarenteed, infact my 6800gt could only do 385/1050 stable with no arties, i didnt really keep it long enough to try vmodding but yeah mine wouldnt have been stable as an ultra...i had a galaxy 6800gt with nv5, i just put it down to the fact i must have got a bad sample
    Opty 144 0546FPMW @ 2.8ghz
    MSI K8N Neo 2
    2 x 512mb OCZ Platinum Rev. 2 TCCD
    ATI X800 Pro @ 570/1200
    Plus some other metal fings...
    Will do me till Conroe
    Heat
    Jan 2005
    Oxford, UK
    my 6800nu was happy at 430/970, 24/7. With 16 pipes, ofc.
    I think with a little effort, most 6800gt can reach 6800u speeds. Just some easier than others.
    Conroe E6300 ES
    2x1gb Ballistix PC8000
    Asus P5W DH Deluxe (1705)
    Manli Geforce 7950GT 512mb
    Hiper Type-R 480w
    Samsung SP250
    "What did the quantam duck say?" "Quark Quark"
    Jan 2005
    Slovenia -> Ljubljana
    where can I download Gainward GS GLH bios?
    Gigabyte 890GPA-UD3H
    AMD Phenom II X6 1055T
    Kingston HyperX 2x2GB DDR1600
    Asus A5770 1GB
    ***CPU & GPU H2O cooled***
    Apr 2005
    my friend eVGA 6800GT AGP revision did with stock cooling 425core and 1216 mem..., nice ha?
    2500K @ 5ghz 1.344V + TRUE 120 Black
    ASUS P8P67 Pro Rev 3.1
    Micron 4GB x 2 1333mhz CL8
    Gigabyte GTX 470 SLI + Zalman VF3000
    Crucial M4 128gb SSD +
    2x Samsung 103SJ, 1x Hitachi 2TB 7K3000
    Antec High Current Gamer 900W
    Lancool PC-K62WB
    Jul 2005
    Netherlands
    My 6800GT did 420/1125... But not without artifacts... Now it only does 410/1070 without artifacts and this is watercooled... Maybe because I've got one of the first GT's not yet with PCI-E power connecter... ( One molex )... Still need 2 voltmod but I'm to lazy.
    Asus P5B-deluxe | E4300@3200mhz | 2x1024MB 400Mhz 4-4-4-12| Asus X1950Pro |
  18. #18
    Feb 2005
    Belgium
    Mine does 445/1200 with Zalman heatsink on it @ 1,5V (PCI-E). To damm it doesn't work anymore since it's large undervolted (Vgpu = 0,8V) when I tried to Vmod it.
    Hope we can get it fixed
