Hello,
I want to overclock a Pentium D840 Extreme Edition. I need which for it: an Engineering Sample or be enough a normal one?
Kind Regards
Drow
Hello,
Kind Regards
Drow
Who can procure me an Engineering Sample of this processor, announces itself over Private Messaging, please.
rofl...sry, but this is too much...
Intel P-M 730
Asus P4GD1
Aopen 7800GTX
1024MB BH5
Personal Records:
P4@5400MHz, P-M@3,2GHz: BH5@289MHz 2225; FSB 350MHz; EB@396MHz 4228; Temp@ -189°C^^
you can overclock a normal one or an engineering sample one
the ES one has unlocked multipliers i believe
You don't need an engineering sample for the 840EE proc. The advantage of an engineering sample is that the multi is unlocked. It is already unlocked for the 840EE. So there is no need to look for an engineering sample of it.Originally Posted by Drow
Asus P5WD2 Mobo
PD LGA775 830 3.0x14 @ -> 4.2 ~ 300fsb
2x512 Corsair 8000UL @ 500 ~ 3:5~ 4,3,3,4
2x74GB WD Raptors SATA RAID0
Plextor DVD-R/CD-RW
Swiftech MCW6002-775 CPU Block & MC650
D-Tek Pro120 Rad, Sanyo Denki 120mm Fan
Swiftech MCX775 AS Ceramique
OCZ Powerstream 520
BFG 7800GTX
Heatware
Can give me someone an example or a screen of an D840 EE (not engineering sample) on which I can see that the CPU is unlocked CPU-Z, ....?
why do you need cpuz screene . People here ar knowlegeble enough about this . If they say it's unlocked it is.
"can anyone supply me engeniring sample " i'm beat , hehe
Abit IC7 P4 2.8a @4.21 | P4 3.4e @4.9 | Gainward 6800GT GS @486/1386
Asus P4P800 SE Dothan 730-PM @ 2900 | EVGA 6800 Ultra GS @521/1376
e8400@4.3G & 8800GTS G92 800/1932/1132 as gaming rig 24/7
Custom self build chillbox with watercooling @-28c 24/7 | chilled wc " cpu -18c idle/-3c load
3DMark 2005 Score Dothan & 6800U
3DMark 2005 Score p4 & 6800GT
I don't doubt that. Why then did Fugger have an engineering sample to overclock one?
why dont u have a look on the intel website
and put the sl codes in to see if we are correct.
What's the sl-code of the D840EE-CPU? I tried to find out something about the multiplikator with the Specfinder. But it stands here nothing about the multi.
Here a link of my research: LINK
FUGGER got his prior to the public release afaik.
And he works for intel
Opteron 165
Dfi NF4 Expert
4x1 1GB twinmos PC 3200
XFX 7900GT 550/1500
because intel supplied him with a cpu for testing purposes
it is unlocked , dont wory
Thus I can take each D840EE. Everyone has the multi free, as their me describes it here. Is that correct?
For this reason Fugger had an Engineering Sample. Not because the multi is locked.
FUGGER works for intel?Originally Posted by Crankster
This is the first I've heard of it.
works= tests i think. Intel dont officially support overclocking do they?
cORRECT!! everyone of them will be multiplier unlocked as all 6XX new stepping cpus are. PM Fugger if you want confirmation
wow wow brother.
6XX ? as well
stepping info please.
WHAT????????????????
Someone is saying that the 661 I have coming will be/might be unlocked? Fugger, please PM me and say it's true Also, if you can confirm that the 955XE retails are unlocked too, I would appreciate that.
The retail Extreme Edition chips starting with the 840EE are unlocked. The 840 EE has multipliers 14x-60x unlocked and available for selection. The 955 Extreme Edition is also unlocked, but has the added advantage of have 12x-60x unlocked (adding 12x and 13x).
How low a multiplier that can be selected is primarily determined by the support from motherboard manufacturer (some support lower multis than others). For example, my 3.2GHz EE (Socket 478) has an official unlocked range of only 12x-16x. It can actually can use 8x and 10x as well, when it is used on my Abit IC7Max3, but on my Gigabyte 8KNXP Ultra 64, 12x is the lowest selectable multiplier. I think for the Smithfield CPUs, as Prescott, only 14x-60x was officially defined. For Presler, Intel defined two more multipliers, 12x and 13x (basically the motherboard maker must include support for those multipliers). The 60x upper limit is a reminder of where Intel had expected the 90 nm CPUs to run at...making all those multipliers above 30x is pretty much totally useless.
For a hardware-level analysis of the mutliplier range of an Intel CPU, look at a SiSoft Sandra report. You will typically see 4x as a low end multiplier for Intel CPUs (meaning that it would work if support was there in the BIOS).
Server: HP Proliant ML370 G6, 2x Xeon X5690, 144GB ECC Registered, 8x OCZ Vertex 3 MAX IOPS 240GB on LSi 9265-8i (RAID 0), 12x Seagate Constellation ES.2 3TB SAS on LSi 9280-24i4e (RAID 6) and dual 1200W redundant power supplies.
Gamer: Intel Core i7 6950X@4.2GHz, Rampage Edition 10, 128GB (8x16GB) Corsair Dominator Platinum 2800MHz, 2x NVidia Titan X (Pascal), Corsair H110i, Vengeance C70 w/Corsair AX1500i, Intel P3700 2TB (boot), Samsung SM961 1TB (Games), 2x Samsung PM1725 6.4TB (11.64TB usable) Windows Software RAID 0 (local storage).
Beater: Xeon E5-1680 V3, NCase M1, ASRock X99-iTX/ac, 2x32GB Crucial 2400MHz RDIMMs, eVGA Titan X (Maxwell), Samsung 950 Pro 512GB, Corsair SF600, Asetek 92mm AIO water cooler.
Server/workstation: 2x Xeon E5-2687W V2, Asus Z9PE-D8, 256GB 1866MHz Samsung LRDIMMs (8x32GB), eVGA Titan X (Maxwell), 2x Intel S3610 1.6TB SSD, Corsair AX1500i, Chenbro SR10769, Intel P3700 2TB.
Thanks for the help (or lack thereof) in resolving my P3700 issue, FUGGER...
I figured the minimum multi would be lower than Prescott (14x) since even the 2.8GHz Presler will have EIST enabled at some point (so it has to be lower than 14x).
Thanks for the detailed info though. Interesting to hear that it will run different min multis base on the mobo/BIOS.
I guess I'll know soon enough (hopefully tomorrow), but if someone can confirm that CedarMills are unlocked too, I'll be able to sleep tonight
Why do you dig up such a old thread? There are some threads about cedar mill I believe, check 'em first.
Intel FTW!
Beanna
Pardon me for posting in an "expired" thread
If you must know, I was searching to verify that the 840EE retails were shipped unlocked and happened to come across the 6xx unlocked post...
