hi guys, i have a big problem/ question and i really will appreciate anyone who have experienced this same issue
i bought a pair of mushkin level one pc3500 1gb kit 512mbX2 (ch-5 chips).. and they were working perfectly at 3.5v 260 mhz 2 3 2 6 for the 5 days that i oc to that speed, voltage, latencies..
but then i changed mi processor from a 3200 winchester to a 3200 venice, and when i tried to start my sistem, a failure in the boot sequence of my lanparty appeared..( see my signature to know) after several tests i found that 1 of my memory stick kit was the one that was causing the failure cause it was i guess dead, and the other one works and boots perfectly..
so my question is... I live in Mexico and my warranty is from newegg.. anyone of you knows that if i send my ram kit.. is there any good chance that newegg replace or repairs it?? due to the fact that i put it 3.5 V on the ram for the 5 days that i used that speed.. cause i really try to avoid the 60 DLLS that i need to spend to send newegg my ram and to be with the maybe or maybe not question of the warranty validation and product replace..
so i really would appreciate any comment or suggest..
thx a lot
