+ Reply to Thread
Results 1 to 6 of 6
Thread: DDR400 to DDR6++ ?
    Jun 2005
    0
    DDR400 to DDR6++ ?
    hi
    I m looking for DDR400 Ram with tccd chipset can reach Over 600MHZ with low timings (cl2 - cl2.5) and works great with amd64 venice core
    Xtreme Enthusiast shuRe's Avatar
    Dec 2004
    Hampshire, England
    0
    you wont find tccd to do cas 2 at ddr600, and you will have a 1 in 10000 or greater chance of finding bh5/ch5 that will do ddr600 @ cas2.
    Your best bet is to look for tccd with bp, possibly something like the new geil coming out, but its a bit hit and miss
    Jun 2005
    0
    hi
    ANYWAY
    Which rams start from PC3200 - PC3500 Can reach ddr600 with good timing for performace
    Registered User insayno27's Avatar
    Dec 2004
    Jackson, CA
    0
    You would do well with some TCCD. Try some G-Skill. I have a gig of FE and its rated 2-2-2-5 and ddr400 and 2.5-3-3-7 at ddr550. I have seen people get it as high as ddr600 2.5-3-3-7 but thats if yer lucky.
    Xtreme Guru i found nemo's Avatar
    Jan 2005
    waukegan
    0
    utt
    Jun 2005
    0
    thanks for replay
    there is OCZ EL PC3200 PLAT REV2 AND PATRIOT PC3200 XBL AND CROSAIR TWINX1024-3200XLPT
    WHICH IS THE BEST OF THEM ??
+ Reply to Thread
