Results 1 to 13 of 13
Thread: BH-5 vs UTT vs TCCD if...
    Jan 2005
    indonesia
    where is the best if i ....try with LanParty...NF3 250Gb..
    Jun 2005
    tccd I think
    Because the voltage
    May 2005
    Arizona State
    uhh.. he can get up to 4v vdimm. if that isnt enough then damn your BH5's love voltage.
    Q6700
    MSI P35
    8GB OCZ
    2xHD 2900 XT
    PCP&C 1kw
    Jan 2005
    indonesia
    UTT with 3,1V can run 300Mhz 2-2-2-5
    but can't run with div 1:1
    with A64 2800+ (dfi lp nf3 250gb)
    MUSIK KU KERAS
    KOPI KU KENTAL
    KRATON ROKOKKU
    sorri if my english to bad..!!!
    Cyanide Blood
    Dec 2004
    England
    ^ so therefore it cant run at 300mhz 2-2-2-5 with 3.1v
    UTT and BH5 will do around 260mhz 2-2-2-5 with around 3.6v, TCCD is your best bet for very high memory clocks but slower timings (higher clocks make up for it tho)
    AN OPEN MIND, WITH A CLOSED FIST.
    Jan 2005
    indonesia
    not...
    this my system
    DFI LP NF3 250Gb
    A64 2800+ S 754 @2700 300X9 Vcore 1.8v
    TM SP UTT 256mb X 2 @300Mhz 2-2-2-5 (in bios 3.4v but i look in MBM just 3.1v)
    all with div 6:5
    MUSIK KU KERAS
    KOPI KU KENTAL
    KRATON ROKOKKU
    Xtreme Cruncher
    Aug 2002
    Michigan
    Quote Originally Posted by endo
    not...
    this my system
    DFI LP NF3 250Gb
    all with div 6:5
    The UTT isnt running 300mhz, its running @250.
    Jan 2005
    indonesia
    ooo......
    my utt can run in 300 with 3-4-4-8
    divider 1:1
    MUSIK KU KERAS
    KOPI KU KENTAL
    KRATON ROKOKKU
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    ooo......
    divider 1:1
    So why don't You post a CPU-Z.......... ?
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
    Apr 2005
    ooo......
    divider 1:1
    Which memory? VX? REdline?? What voltages do you use to get to that
    Intel Core i7 930 @ 4ghz | Gigabyte X58A-UD5 | 6GB G.Skill Ripjaws DDR3 | Radeon 4850 | Crucial m4 128GB SSD
    Intel Core i5-2400 | Asus P8H67-M EVO (Waiting to change to Z68) | 8GB G.Skill Sniper DDR3 | 8x2TB Samsung F4-HD204 | OpenIndiana | ZFS raidz2
    Apr 2005
    Correct me if I am wrong, maximum voltage for BH-5 is 3.6v, is it the same for UTT?
    In many cases a full 4v in boards like DFI NF4, would that kill BH-5 in no time?
    Jun 2005
    the Netherlands
    Quote Originally Posted by deltarealm
    If you are not using descent memory cooling, YES... 3.6v seems to me like the max 24/7.. for some benches you can use 3.7 - 3.8v of course
    EDIT:
    I have some TCCD doing 330MHz @ 2.5-4-4-8. What speeds @ 2-2-2-5 are comparebale in benchmarks to my TCCD?
    AMD64 3000+ venice max PIfast 2881MHz, 41.** seconds, DFI NF4 DAGF, 2 x 256mb twinmos twister pc4000, 2 x 256mb G.skill pc4800LA , 6600 128 mb.
    Jun 2005
    the Netherlands
    Quote Originally Posted by pleasure
    EDIT:
    anybody?
