No its not. It takes advantage of HT. And last I checked that wasn't "bogus". And didnt know if you knew, BUT AMD A64 doesnt have HT, only the X2 can make use of those isntructions.Originally Posted by agenda2005
-EvlNome
AMD X2 3800+
DFi LANPARTY UT NF590 SLI-M2R/G
2 x 1Gb Crucial PC8500 [Anniversary Heatspreaders ]
Custom Watercooling on the way
Thermalright XP-90 right now
27" 1080p HDTV for monitor
Originally Posted by The Inq
im amazed that theres not more people with higher scores than me... i ran at stock speeds, (3.4, 200fsb) with the vid card at 406/1.12 and got this http://service.futuremark.com/compare?pcm05=8862 . it may be worth mentioning that OCin the vid card gained me a mere 69 points over running everything at stock, compared to 04 where the vod card OC gained me about 200. i tried running at 4 ghz to see just how much this benchmark likes speed, but for some reason, the same settings i use for all the scores in my sig, with 1.4625VCore in BIOS, it crashes in PCMark05, dont know what the problem is. it always crashed at the same test, the one where it does video encoding and audio compression. upping the voltage didnt help. cant wait to get a new PSU, this P.O.S. thermaltake has 18 measly ****in' amps on the 12V Rail . have a feeling that will help loads.
"Roses are FF0000, Violets are 0000FF, All my base are belong to you."
Asus P6X58D-E
I7 930 @ 3.9
Asus 660ti DirectCU OC
Antec Twelve-Hundred
I run all the tests, but never get a score. sometimes it crashes too
says you must run system suite to get score, but im running all the tests available!!! stupid benchmarks
Well, mr_knowitall15 & Peen maybe you should downclock your systems a bit.
I too have expirenced that PCmark05 is more demanding to run than PCmark04. It crashed easier, but that's just because our systems are not 100% stable at the speed we are running those other benchmarks.
If I need to be 100% Prime95 stable (over night stable) I need to run no higher than 3.8 Ghz, but PCmark04 could be run at 3.93Ghz and PCmark05 can be run at 3.85 Ghz.
So try running stock speed and see if you can get a score before blaming the benchmark.
I know when my system is stable, thank you. It runs prime95 24hrs+ and games all the time and encodes when its not gaming. It has never crashed once. Im blaming the benchmark
Well do what you want, but I'd suggest start trouble shooting the problem instead of just blaming the benchmark.
Well I wanted to try it, but its not a big deal and I dont really care what 4 digit numbers it gives me
Some people have problems with the harddrive virus scan failing. That could very well be because of a bug in the benchmark.
I had to unplug my firewire/USB disks otherwise the system would bluescreen during the hardware detection.
My point is I think it's unfair to blame the benchmark before trying the obvious things first.
But it's a free world.
It works with a different video card, not sure why though. It ran all the tests but I guess the 3D parts were whacked somehow. All other benchies worked fine on it though. Only got 3970 with system in sig with stock 9800Pro
edit: Messed up video card settings screwed up 3d parts so low score, and my HD is dying so low score there too
Here is mines. 2nd system specs:
a64 3400+ stock
1gb ram
Gigaybte Nforce3 250gb
PNY geforce 6800 GT
http://service.futuremark.com/compare?pcm05=14148= 3358
--===== proud owner of new razor tarantula gaming keyboard =====--
Heres mine http://service.futuremark.com/compare?pcm05=14145
but for some reason my videocards performance is extremely low on pixel shader part
niceOriginally Posted by Kristian
Sorry for my bad English.
Rig I:
| I7-2600K | Intel DZ68DB | Mushkin BlackLine 4Gbx2 1333 | Intel SSD 320 | Seasonic M12 520w |
Rig II:
| E2160 (stock) @ 3Ghz | IP35-E | Gskill F2-6400CL4D-2GBHK | Gecube HD2600xt + Accelero S1R2| WD 250 AAKS | Hec Silent Pro 385w |
Fixed my 9800 Pro drivers, put Cat 4.12's on
got 4341 this time http://service.futuremark.com/compare?pcm05=14315
w00t broke 5k with my 3000+ and 6600gt! Link
GA-P35-DS3L no more than 450fsb w/1333 chip
E6550 stuck at 3150
V-DATA 2x1gb
MSI 7900GS 512 3Dmark score in near future
Old A64 scores2001 39,707 3D03 23,768 3D05 11,394 3D06 5914
Pcmark05 = 4,935
Originally Posted by eva2000
235s your memory maxxed Eva2000 ?
if not, get them maxxed ( combined with your cpu max )
Okay my score is 4158.
Compared to some of your results I feel really bad... ;-)
I'll upload a pic later.
nah not max just slowly building up as i only had cpu for a few days but mem bandwidth doesn't make much diff in pcmark05Originally Posted by [Cipher]
i just tried 283HTT/257mhz 2-2-2-6 and got 4944
Pcmark05 = 4,944
http://service.futuremark.com/compare?pcm05=17687
yes, you missed the bug.Originally Posted by pancake
check page 1 ( i think it's mentioned inside this topic )
Thought I'd run it on my 24/7 rig just to see how it fared...
3200 newcastle
Max3 mobo
9800xt
120gb ide
512 ddr 2.5-4-4-8
All bone stock on air
http://service.futuremark.com/compare?pcm05=19049
3300 marks...not bad I guess for a rig that only surfs the net and plays a game here and there...
Not exactly 'Xtreme' but I'm a week away from the benching rig being done, so may as well bench what I've got lol
[SIGPIC][/SIGPIC]
I think I can break 5k easy with single cpu. I noticed 9800Pro seems to suck at this test, and impacts it pretty good. different vid card and some more cpu clocks should give me more then 5k maybe?? I noticed 6600GT's rock at this too
My best so far.
DFI SLI-DR | Opteron 170 Mach II | 2x512 G.Skill LE | x1900XTX | 2x250GB Hitachi T7K250 RAID 0 | PCP&C 510 SLI | Creative X-Fi
My Heatware
Yeh I have been getting really low scores sometimes how do u fix the bugOriginally Posted by [Cipher]
