I have a refrigerator out of a truck, it runs at 24 volts.
Would that be enough to chill a cpu.
Note, i would be satisfied with temps lil bit under 0° load.
It is meant to cool a venice 3500+, will be oc'ed.
We need more details. What kind of "refrigerator"? Do you mean air conditioner?
If you can get some pics that would probably help, too.
7700k @ 5.0GHz
ASUS Z170-Deluxe
2x8GB Avexir Raiden DDR4-3000 15-15-15-35
Gigabyte Aorus 1080 Ti @ 2076/1500(6000)
512GB Samsung PM961 + 840 Pro 256GB + some TBs
Corsair AX1200i
X-Star DP2710LED @ 110Hz + 40" Samsung TV
CPU and GPU under water: 9x120 rad + 3x120 + 3x120
...and an HTC Vive!
sorry, but i havent got the fridge here, so cant take a pictureOriginally Posted by mcnbns
all i know is that it comes from a volvo
edit: it is an inbuild frigde for in a truck
the cooling unit is loose from the console itself where you put youre drinks in
it is connected with two rubber isolated bendable tubes
You'll need a fairly large 24 volt supply. Probably not worthwhile IMO.
a transformer 220v/24voltOriginally Posted by saratoga
edit, it was connected to a battery, cant be this amp asking.
I think a transfo will supply more than a battery, dont you think?
If it isn't "amp asking" ( ) it isn't powerfull enough mate.Originally Posted by 1337mr.hanky
You need atleast a 160W compressor for phase-changing a cpu, any lower and it just can't handle the load. 160W still hardly handles the load.
Blue Dolphin Reviews & Guides
Blue Reviews:
Gigabyte G-Power PRO CPU cooler
Vantec Nexstar 3.5" external HDD enclosure
Gigabyte Poseidon 310 case
Blue Guides:
Fixing a GFX BIOS checksum yourself
98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
well, i have two compressors in here, but they look lot different than the unit i'm talking about.
Maybe i can use another fridge, but that one is a lot newer and better, it is a standard looking one, with that one i can replace the compressor by a 220volt one.
Would that be a better id? And than maybe i can fix the older one and put the cooling unit at the new fridge.
Can you follow? Sorry i'm from Belgium, my English isn't that good.
I'm not a pro, I haven't build a system myself. I just did some researching (read: took a fridge appart) and did a lot of reading about phase-change.Originally Posted by 1337mr.hanky
You can get a 220v compressor very easy from old fridges. I'd suggest to forget about the transformer idea. Just get yourself a nice 220v compressor.
If you find a nice one just show some pics of it here at Xs and I'm sure there are a lot of people with the knowledge to judge if it's suitable for the job.
Blue Reviews:
Blue Guides:
Transformers supply AC, batteries supply DC. If its 24v and hooked to a battery, its probably DC (unless you have an inverter on the battery), and will probably be damaged if you give it AC.Originally Posted by 1337mr.hanky
Yeah, 160w is too small for a chiller. Would make a good direct die system though.You need atleast a 160W compressor for phase-changing a cpu, any lower and it just can't handle the load. 160W still hardly handles the load.
He could wire a bridge rectifier in series with the transformer, although like you guys said he'd be better with a 220V compressor, it'll last longer.
# cd /home/fuzzymuzzle.com
AMD Athlon 64 +3700 2.4GHz Clawhammer (Gaming)
*ATI Radeon X800 Pro
*Windows XP Pro x64 Beta
Dual AMD Opteron 244 (Workstation)
*ATI AIW 7500
*Windows XP Pro x64 (Monday)
Intel Pentium 3 1.0GHz (Router/Server)
*nVidia Riva TNT 2
*Fedora Core 4
i have 2 220volt compressors here, but i will need a condensor and stuff aswell
use the one(s) from the small fridge out of the car?i have 2 220volt compressors here, but i will need a condensor and stuff aswell
Even the condensor on a normal fridge is not nearly enough to be used in a phase-change system, let alone a waterchiller, let alone a condensor from a mini fridge
Blue Reviews:
Blue Guides:
Use an A/C unit condenser, you can get one for cheap off of eBay.
*ATI AIW 7500
*nVidia Riva TNT 2
*Fedora Core 4
Hi, you mention truck refrigeration?
What model and make is the refigeration unit?
I fit and repair these things for a living and I know for a fact it can be done, the question is though, how much hassle do you want?
Also to answer an above question, if it's 24v dc you can run it through a 240v > 24v transformer with a rectifier.
Transformer input 240v ac
Transformer output 24v ac
Rectifier input 24v ac
Rectifier output 24v dc.
Do you know how the compressor is driven?
Is the compressor direct feed 24v for drive or does it take it's drive off the vehicle engine?
edit, i am now wondering if the fridge he speak of is a tiny camping thing like in a motorhome for milk and stuff, if it is it probably wont work.
