Any release date on this? Also, will it use the same bracket at the 7000?
when the 120mm version comes out, im all over it
emptiness
even if you couldnt rotate it then the fan would be blowing the hot air up to the psu fan, which would still be good, i really think this zalman is a winner, depends on how it performs, i may have to ditch my watercooling!
Specs
Asus 780i Striker II Formula
Intel E8400 Wolfdale @ 4050Mhz
2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
MSI 5850 1000Mhz/5000Mhz
Wester Digital Black 2TB
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2
Audio Setup
X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
If you have fan underneath the PSU that is...
[DFI nF4 Ultra-D @ 6/15 BIOS] // [Venice 3000+ @ 2.8GHz @ 1.472v] // [2x512MB SP BH-5 @ 2-2-2-8 200 MHz 2.63v... for the moment] // [Sapphire X800XL Ultimate] // [OCZ Powerstream 520W]
Super PI 1M record: 29.969 // Suicide screen record: 3 GHz // LBBLE 0517 DPMW batch ~300 on air // Stable enough?
TB 900 + Venice 2800 folding 24/7, TB 1200 folding whenever it's on, profile
looks cool, I'd love to try one...
if this is really better then watercooling (which I don't buy into just yet) that would make me wonder... why hasn't anyone tried heatpipes, with watercooling
Originally Posted by Kunaak
I doubt this is any better than watercooling, but the performance could be close. Makes watercooling kind of worthless at the moment...
hmmmm.... im not sure it would work well, as the heat pipes are used to transfer the heat from the base to the fins, in the case of watercooling the base is the block and the fins are the radiator. i do have some ideas how it could be done though, but i dont think it would be practical.Originally Posted by Kunaak
dont mose psu's have them?Originally Posted by exscape
Specs
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Audio Setup
#32 all the psu's i have had had a fan underneath
i do believe some dont, but i do think its atx standard to have one, but not all psu comply with the standards.Originally Posted by mikael999
Specs
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Audio Setup
ocz powerstreamOriginally Posted by mikael999
Got a fan over those memory sticks? No? Well get to it before you kill them
That thing is huge... HUGE, I tell ya!
Thuban 1090T @ 3.8Ghz | Corsair H70 | G.Skill DDR3 16GB 1600 Cas9 | Gigabyte 880GMA | HD5870 | Corsair AX750 |
I7-875K @ 3.6Ghz w/HT on | Corsair H50 | G.Skill DDR3 4GB 1600 Cas6 | Asus Sabertooth | GTX260 | Corsair 850TX |
Q6600 G0 @ 3.0Ghz | G.Skill DDR2 2x2GB PC8000 | DFI LP JR P45-T2RS | HD3850 | Corsair 620HX |
E6400 SL9T9 @ 3.0Ghz | G.Skill DDR2 2x1GBHK (4-4-3-5) | Intel Bad Axe v3.06 | X1950PRO | Corsair 550VX |
That will sit perfectly infront of my exhaust fans!
too bad u can't use ur own fan - cos i'm guessing it will be a silent cooler... looking at their picture- it doesn't even reach 3000rpm
if the performance is better than an XP120 with a medium speed (ie, 60-80cfm) 120mm fan - then i'm up for it for sure. Hopefully the pricing is not much more than an XP90 though.
dfi nf4, 3200+ @ 2.98ghz on water (soon TEC), 6800U @ 460/1260. gskill GH @ 2-2-2-5
i bet you can switch the fan like with the other zalmansOriginally Posted by groovetek
Specs
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Audio Setup
nice, looks like it's time to retire the XP-120
I might rather have a xp-120 if I was running high voltage ram though...the zalman doesn't look like it does much in the way of helping with ram cooling like the xp-120. What do you guys think?
It looks like you can mount the 9500 in either of 2 directions, so on a DFI nf4 board it could be mounted to blow over the ram modules and out a top blow hole of the case.
While sucking up the hot air coming off of the video card....
Originally Posted by mik2uzl
Why did they not put a shroud around it take out the front indent where the fan is and run push-pull with another fan on the back it would work MUCH better...IDK...zally is nice and perform decent but I only get them when I want silence NOT TRUE performance...
Dragon
http://smbach.com/mad.gif
Opty 175 Rig
Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
AM3 Rig
Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
DFI NF4 BIOS Guide
Yeah, but the outside dimensions of the round part are probably close to 120mm. I say make a custom cylindrical shroud and mount a medium speed 120mm fan on each end. See how well it does then...
i can't wait to get this heatsink. i'm already planning on a mod to maximize airflow. what i'm planning on doing is changing the position of the sink. instead of having is face the psu on one side and the vid card on the other side. i'll switch the position to face the front and back of the case. i know people will argue against this mod, but think about it. i'm planning on adding a 120mm fan to the sink along with the attached fan. ok, this is how i envision it to work. heatsink will face front and back of the case. the side that has the original fan will face the front since it'll push air into the heatsink. the back side will face the 120mm rear exhaust fan. i'll add another 120mm fan on the back side to suck hot air out from the heatsink. so the final setup will effectively be cold air blows into heatsink and hot air sucks out from the sink and exhaust thru rear 120mm fan. i hope that i can switch the mounting brackets . this idea is patent pending . let me know what you think about this.
I'm having similar thoughts. Great IDea but I'm sure that we aren't the only ones thinking the same thing.Originally Posted by dng29
Q6600 @ 3.0 | 8GB G-Skill @ 800 Mhz 5-5-5-20 | ATI 3870 Stock 1 x 500 GB Seagate 7200.11
1 x 1TB Seagate 7200.11 | 2 x 320GB Seagate 7200.10
Seasonic S12-550 Energy +CM Stacker
Screw the smaller version imo zalman should give us the mideum version of that cooler or the big one. It would end all those hp wars from all companies
Originally Posted by Mikesta
if the mounting brackets can't be removed then we can't do anything. i wonder if i can pitch the idea to zalman and see if they'll change the position of the mounting bracket
anyone know when this heatsink will be available online? thanks.
