Results 1 to 21 of 21
Thread: Why do the FX's put out more heat?
    Jan 2005
    Cheshire, UK
    Hey guys,
    In the quest to get 3ghz prime stable, I have been through 5 CPU's in the last 6 months ( FX-53, 3200+ winchester, 3800+ venice, 4000+ San Diego, and now FX-55 San Diego).
    I've noticed on both the FX's that they put out more heat than the other chips, why would this be? Esp as 4000+ SD is almost the same chip as FX SD isn't it?
    Temps seem to be around 5-10 degrees higher on compareable voltage, and pwm temps also go up with FX's (in my case from 34 degrees to 40 degrees. I've only noticed this because I've gone through a lot of CPU's in a short time.
    Oh and still can't hit 3Ghz prime stable (even tho she will boot @3ghz on default volts), this FX does 2.98ghz....so close and yet so far
    Intel Core i7 3820 / ASUS X79 Sabertooth
    Gskill 2133mhz Quad 16GB / Auzentech X-FI Forte
    Sapphire HD5970 OC 2GB
    4x 500GB Western Digital "Black Edition" (Raid5)
    Thermaltake ToughPower 1500w PSU / OCZ 1250W PSU
    Corsair H100
    CoolerMaster CM-690 / Windows 7 Pro 64bit
    Samsung T260HD 26" LCD / HDTV
    Feb 2004
    Sweden
    There is no reason that a 4000+ claw should draw less than a FX-53.
    They are the same chip but with unlocked multis.
    Compared to the other chips the 0.13 nm and 1 mb cache makes the difference.
    Opteron 165
    Dfi NF4 Expert
    4x1 1GB twinmos PC 3200
    XFX 7900GT 550/1500
    Jan 2005
    Cheshire, UK
    Yeah thats what I thought, yet it does happen on my system, i can't really explain it.
    Corsair H100
    Love and Peace!
    Dec 2004
    hiding somewhere!
    i have a suspicion that AMD uses more faster/hotter transistors in the FX line.
    Got a fan over those memory sticks? No? Well get to it before you kill them
    May 2005
    Rye, Ny
    yeah i second ozzimarks comment...they expect people to overclock with the fx so they mite give it a little more headroom
    Oct 2004
    FX-55 Clawhammer supposedly had some implementation of strained silicon, which could explain the higher heat. And correct me if I'm wrong, but doesn't FX-55 San Diego have a default voltage of 1.5v? If so, the reason for higher heat should be obvious.
    Jan 2005
    Cheshire, UK
    Quote Originally Posted by frostedflakes
    Does it? I didn't think it did.
    If i set mine to auto it reads out as 1.35 ish in smart guardian, which usually means its actually 1.4v.
    But what I was talking about was at the same volts, the FX's are hotter, and they also seem to heat up the PWM more too...as if theres more strain on it.
    Corsair H100
    Jan 2005
    Cheshire, UK
    Is the OPN on your processor ADAFX55DAA5BN? This correlates with a 1.5v part.
    Frosted, off the top of my head I don't know, but I will check (I always forget to write it down). I was not even aware that there where FX's with 1.5v as default volts, I thought the AA meant variable voltage???
    Edit: Your post appears to have vanished
    Corsair H100
    Xtreme Cruncher
    Mar 2005
    venezuela caracas
    4000sd venice winnies all are 90nm fx are 130 so more heat...
    Incoming new computer after 5 long years
    YOU want to FIGHT CANCER OR AIDS join us at WCG and help to have a better FUTURE
    Jan 2005
    Cheshire, UK
    My FX-55 SD is 90nm
    But anyway, the FX-55 SD, runs hotter than the 4000+ SD at same volts with same cooling, and the PWM temps are also higher (they are both 90nm). There must be something differant about the FX's, just don't know what it is.
    Corsair H100
    Oct 2004
    Quote Originally Posted by madpete
    Yeah you're right, after I posted I did some searching and realized I messed up, so I went ahead and deleted the post.
    Xtreme Cruncher
    Mar 2005
    venezuela caracas
    maybe is dsl sSOI ????
    Jan 2005
    No(r)way
    Maybe the temp- sensor on the FX chips has been calibrated differently to further remove the chance of the "cold bug" appearing?
    Just a thought...
    Xtreme X.I.P.
    May 2004
    Hammel/Denmark
    The defult volt for a 90nm Sd is 1.35-1.4v ...............
    The whole world's hip and thats not cool !
    Rip Van Hippy
    Doesn't expecting the unexpected make the unexpected the expected ?
    Light travels faster than sound. This is why some people appear bright until you hear them speak
    Feb 2005
    USA
    possibly better memory controller and lower latency cache..... have you try to bench both 4000 SD and FX55 SD side by side at the same clock speed on same voltage and see if there's any difference?
    Core i7 920 D0 3844A717 4.40Ghz HT on @1.36v (LinX/Prime/3D stable), Corsair 850W, 12GB OCZ Platinum 1600, P6T Deluxe V2, EVGA GTX 285 SS, OCZ Vortex SSD 30GB x3 RAID0, HAF 932.
    Water Cooling Setup: XSPC RX360, MCP355 + XSPC Res Top, Swiftech GTZ, 1/2" Tygon, Scythe S-Flex SFF21F push, 20mm yateloon D12SL-12C pull.
    Opteron 148 CABNE 0528 GPMW 3.1Ghz @1.6v Prime Stable. Westy 37" LVM-37W3, DFI Venus 975, 2GB TeamX Cronus Micron, GSkill HZ, Sapphire X1900XTX, Zippy 700W, X-Fi Xtrememusic, 36GB Raptors x2 @Raid-0.
    WC Setup: PA120.3 +Shroud, MCP655, STORM, MCW60, 1/2" Tygon, mini res, Yate Loon.
    Jan 2005
    Cheshire, UK
    Quote Originally Posted by ben805
    Ben, no not conducted any side by side benchies, just an observation on my system. It could be as you say, it could also be the calibration of the temp sensor as has also been mentioned but that does explain higher PWM temps too.
    Corsair H100
    Feb 2005
    USA
    if someone can do a side by side comparison and confirm the FX to be superior to regular SD...which I think it should, then you got your answers.
  18. #18
    Love and Peace!
    Dec 2004
    hiding somewhere!
    Quote Originally Posted by leviathan18
    DSL = dual stress liners = fancy name for strained silicon
    frodin: i don't think the temp sensor has anything to do with the cold bug. after reading around, i think it's the memory controller failing when it gets really cold. this is just my theory though
  19. #19
    XIP
    Nov 2004
    NYC
    @madpete, what week is your fx55 sd?
  20. #20
    Jan 2005
    Cheshire, UK
    Quote Originally Posted by Dumo
    Dumo,
    0513 mate...
    ADAFX55DAA5BN - CABCE 0513MPAW
    Corsair H100
  21. #21
    XIP
    Nov 2004
    NYC
    Dumo,
    0513 mate...
    Interesting, mine is 0511 CABGE-MPMW. Lets compare notes
