Air Conditioning.
The cold water is piped through what are called Air Handlers, basically large radiators, into the ventilation system which cools your building.
Air Conditioning.
Regards, Stew.....
- This message brought to you by Frank Lee E. Snutz
U-bend on discharge is useful, because at start and stop compressor shakes sharply
and joints on this line have a heavy job in resisting those shakes.. and someday you
can hear pssssss
Stewie, this place looks very interesting, is it your work place (and what is it)?
I just waited for somebody who comments thisOriginally Posted by Master_G
Well, i (usually) dont go modelling with them
Yeah, really no fun, i'll get a new on monday.
sick..Originally Posted by Stewie007
btw, nice to know how to calculate it, thanks
Well, the discharge line is really long and flexibel, as L'Unite build they're units like mine i think it works. Good to know for the little brother, it will be nearly the same design but much smaller, so this could be a problem.Originally Posted by Tonic
dual ... quad ... hexal ... octal ... hexadecal?
"let's get on with the rock... and roll"
The heatexchanger, well, more "an early prototype"
19 (well it are 18, the last one is not in the pic) 28mm pipes, the pipes the water will flow through.
This is what it will look like when assembeled, its really heavy...
...and in position
The "rests", still secret what will happen to 'em
with insulation, it will have a total height of 270mm IIRC.
Looking good, where do you get that foam insulation tube?
If you have a cooling question or concern feel free to contact me.
JEEBUS!!!!
lol
craftsmanship is exceptional
that HX is gonna be huge with all of the insulation.
That thing is going to be insane once it's finished - period. And from the looks of it so far, I think the end-product will look very professional. I hope this project works out in your favor, Sidewinder.Originally Posted by MaxxxRacer
one word ..... MONSTER
emptiness
It's Armaflex from ArmacellOriginally Posted by n00b 0f l337
Now i need to build the evaporator....
20x 50mm pipe, expanded on one side
10x 140mm pipe
5x 300mm pipe
4x 305mm pipe...
going to be fun :/
wouldn't it be better to simply insulate the hole heatexchanger in one piece ant not to insulate every single pipe?
Did you already solder it together?
A lot of brazing fun is waiting.. good that you have kilograms of braze rods
Tell me, where's evaporator section and where's coolant section?
I agree, but looking sweet though, can't wait to see the temps.Originally Posted by MaxxxRacer
Think that's one advantage of living in europe, clean 220V power. Dunno about elsewhere in the US, but the power in NYC is absolute garbage, at least where I am. I'd kill to break away from this 110 amp hungry system..Originally Posted by _HL4E_HalfLife_
I'm also curious to see the beer cooling module
Nothing pleases me more than seeing German perfectionists machinery
Big heatexchangers has disadvantage of bigger thermal loss but i guess system this big just needs one. Lamel type heatexchanger would be small and damn effective but i guess they are too hard to make yourself. Pretty expensive too
This project is a candy for an eye..
I would'nt say it would be better, but faster to realize... but i prefer this method, looks better, lolOriginally Posted by Jonny
yepp, can't wait, lol...Originally Posted by Tonic
I will put a second pipe (12mm) into the 28mm pipe, the 12mm will be the evaporator, the coolant will flow through the 28mm pipe.
I can't wait also, i hope the EC2/EX2 works fineOriginally Posted by specialblend218
I'm tooOriginally Posted by illmatik
Indeed. Can't wait to see what's nextOriginally Posted by ilkkahy
That is absolutely fantastic workmanship bro
Xceptionally nice build you have going
so you are gonna have the evap running the entire way through the HX? I wonder if the compressor has enough guts to get the evap sub zero the entire length of it.
Yepp, correct.Originally Posted by MaxxxRacer
The evaporator has a total length of ~5200mm, so it will have a capacity (WT) of ~ 0.41 liters, thats more than the capacity of the industrial HXs, but i wont use water as coolant, i will use Antifrogen KF and the heatguidancecoefficient is lower on mine. Through simple calculations the size is correct.
wow thats one crazy long evap. do you think the evap will have a rather consistent temp along the whole lenght of it or will it be cooler at the begining of the evap?
yes, and i will use this effect, like the Liebig condenser does.
Originally Posted by Sidewinder
how do you want to use the effect, I dont have a clue, what the liebig condenser does
lol, you should remember it from school...
it was the thing used to condense alcohol, its made of glas:
http://images.google.de/images?q=Lie...r=&sa=N&tab=wi
