Hey anyone got something for this board ?
i check the vdimm... 4V vdimm mod is not possible
so 3.2V is the max... sorry
I don't need more than 2.9v anyway
But maybe there's some magical trick with which I can get 100mhz more on cpu or something
Is there Active Armor Nvidia Firewall on this board?
what about the rail of PSU..can this mobo use the 5v rail (VR) for the vdimm...?
Nope..Originally Posted by ilyas
3.2v is max.. and TicTac stated above that he tried to unlock higher vdimm options and it was not available..
Since the Vdimm Options go up to 3.2v I think it's using the 3.3v rail
BTW Tictac is it possible to make the vcore steps smaller, because it's like this atm
1.50 1.55 1.65 1.75 1.85
and that kinda sucks, the link to the BIOS is here, would be great if you take a look at it!
http://www.dfi.com.tw/Upload/BIOS/CK84D527.zip
Have you tried CPU Voltage Offset combination?Code:CPU Volatge offset +0.000V +0.025V +0.050V +0.075V +0.100V +0.125V +0.150V +0.175V +0.200V +0.225V +0.250V +0.275V +0.300V +0.325V +0.350V +0.375V Excess CPU Voltage +0.0V +0.1V +0.2V +0.3V
If you set "Fixed CPU Voltage" to auto.. and then enable "Over Voltage on the fly" it will let you add voltage to the stock voltage of your chip in smaller increments..
edit..
TicTac beat me..
That doesn't work for me, Offset is always set to 0.025 no matter what I set it to, when I reboot it's at 0.025 again..
P.S.: I already tried different BIOS, everytime the same
Originally Posted by sai
I had the same problem with the 5-27 beta bios that I was trying.. flashed to the 4-14 bios and it was working all last night through my testing..
edit..
Sorry I read to fast and didnt see you tried different bios.. 4-14 is working fine for me..
I think you NEED to leave the Fixed CPU Voltage at auto and then use the Offset from there.. I tried to set the Fixed to a specific value and then add with the offset and I think that messed it up.. maybe try and reflash it..
But with 4-14 the ram totally sucks.
Works fine with my Sandy and tcc5.. you dont have a sig so I have no clue what you use..
I was stabilizing 265x11 last night..
Well I just flashed the 4-14 and it works good but still I can't get the cpu any higher
So I'm burning that whole ing cpu down now
Just remember that Fixed CPU Voltage has to be @ auto for the offset settings to work.. im not sure but I think thats what messed mine up before..
GL..
You burned in your cpu ? Did you gain anything ? This darn stuff never worked for me before...and it seems like it still won't
No I didnt.. I dont believe burning in cpu's do as much if anything as burning in winbond ram..
which 4-14 BIOS u use?is it 4-14-(1) ... (2)..OR (3)...???Originally Posted by THunDA
Using this board with Winnie 3000+ and 2 x 512MB Kingston DT-D43 (double-sided)
manage to get 260MHz, 2.5-3-3-7, 1T, at 2.9v
5hours of memtest #5, no error ,
but how to get rid of memtest #8 errors ?
Anyone one here try the latest beta BIOS?
this one > CK84D527
sorry... this is not DFI nforce4 ultra D thread...Originally Posted by ilyas
it is DAGF version... they use different bios
Originally Posted by ahpaul82
Yeah but Voltage Offset doesn't work properly, so it's useless for me.
yes it has active armour nvidia firewall, and considering the lack of stock sinks, you wouldn't want to try 4v without mods...
[QUOTE=ahpaul82]Using this board with Winnie 3000+ and 2 x 512MB Kingston DT-D43 (double-sided)
no one can anwser me ?
Intel Core 2 Duo E6600 @ 3200MHz
CoolerMaster GiminII Cooler + AC RYAN 12CM Fan
2 x 1GB Kingston ValueRAM DDR2-667 @ DDR800, 44412, 2.0v, Black slots. (Hynix FP-Y5 RAMchips)
ASUS P5N-E SLI (BIOS 1201) 1.56v chipset
ATI Radeon X1950GT 512MB (PCI-E)
TDK 52X48X52X16X Combo Drive
2 x WD 36GB Raptor SATA 8MB in RAID 0 Mode
SEAGATE 320GB SATA2 16MB
MAXTOR 200GB SATA2 8MB
Samsung Floppy Drive
Audiotrak Prodigy 7.1LT Sound Card
Lian Li PC65B+ Casing
Corsair TX Series 750W PSU
Window XP Pro SP3
playing with a64 tweaker and increasing voltage didn't help ?
