+ Reply to Thread
Results 1 to 6 of 6
Thread: could someone re-direct me on how to learn....
    Xtreme Addict Daveb2012's Avatar
    Apr 2005
    Orange County, CA
    0
    well I have my rig put together finally today, and im trying to figure out where to begin learning when it comes to Over clocking DFI boards. I have:
    dfi nf4 ultra-d board
    venice 3000+
    ocz 520w powerstream
    512 x 2 ocz vx 3200 gold
    pci-e ati x800xl
    all on air.
    ect...
    I have no clue honestly where to beggin with over clocking this I have read and understand over clocking just have never attempted to apply it. and I would like to do everything right if possible. Can someone re-direct me to a good read/link on where to beggin with over clocking this board. I figure everyone here had to learn some how so hopefully someone can help me out. thanks in advnace.
    Mar 2005
    houston TX USA
    0
    go to the best of amd section, that's where ull find most the mobo specific threads
    emptiness
    XS D2OL & RAM News jjcom's Avatar
    Aug 2004
    Somewhere, USA
    0
    yep, guides and tweaks, tips, etc would be found there.
    Look through the threads on different A64 tweaker timings people have posted, that will come in handy with overclocking your RAM possibly.
    jjcom
    Xtreme Mentor
    Oct 2004
    0
    Another item to remember is to overclock one component at a time. This is especially true in your case because your system is new and you do not have an idea of how each of your components perform. I would start first by overclocking the CPU. Find your maximum CPU overclock while trying to keep your RAM as close to stock speed as possible. Once you have that figured out, make a note of it and move on to the RAM. Find your maximum RAM overclock while trying to keep your CPU as close to stock speed as possible. From there, you can balance everything out and come up with a sweet spot for best overall system performance. After all is said and done, move on to your video card.
    Apr 2005
    Orange County, CA
    0
    Quote Originally Posted by conrad.maranan
    Good advice thanks a lot. I have over clocked cpu only by changing FSB, I think I need a different bios to change other settings not sure..
    Aug 2004
    Somewhere, USA
    0
    There should be something in the BIOS on changing the CPU Multiplier, as well as dividers, etc. There are different BIOSes that are optimized for different RAM types, you may want to find one for Winbond chips.
    jjcom
+ Reply to Thread
