Page 5 of 6 FirstFirst ... 23456 LastLast
Results 101 to 125 of 134
Thread: chipset cooler dfi ulltra d sli
  1. #101
    Dec 2004
    We should all post our idle/load temps of the NB with our cooling solution. I have AS5 on my stock heatsink and idle is 35-40'c (depending on time/heat of day).
  2. #102
    Phenom™
    Sep 2002
    Quote Originally Posted by kriz
    hi, my first post on Xs
    i live in austria and here it is very hard to find the vantec iceberg cooler and special stuff that dont sells well today i came across this Revoltec vga cooler. it looks exactly like the iceberg.is vantec and revoltec the same company? or are they workling together?
    what do you guys think will it fit on the lanparty ut nf4? anybody running this setup? the mounting holes sould be fine -right? do i need to get aditional screws and nuts for assembling? i remember a post here at xs where somebody said he had to dremel his vantec iceberg, i will look that up later.
    thx and sorry for my bad english
    WELCOME TO XS kriz!
    That cooler is probably exactly the same as the vantec cooler. Many times, companies just relabel heatsinks which are manufactured in the same factory. My spire cooler is also identical to the vantec. Check post #8 of this thread - the revoltec should mount exactly the same....
  3. #103
    Apr 2005
    Norway, approx. 1367Miles from the Northpole
    My system becomes complete at the end of the week.. here`s a sneak peak
    Live to Mod.. Mod to Live!
  4. #104
    Jul 2005
    oh you are right it is in this thread, its too late for me buddy damit multitasking ; )
    where exactly have you dremeled your spire cooler s7e9h3n? the stock one is too loud for the poor performance..
    @ArcticOC
    this is relly kewl!
    @unreal
    will post my temps tomorrow with closed case
  5. #105
    Dec 2003
    Over here!!
    ^^Hey, that looks sweet, and cool.
    I didn`t read the whole thread, but my DFI SLI NB fan failed too, I replaced it with an old Saffire 9800 pro heat sink and fan. Temps are about the same, and no RPM sensing, but what the heck, it works.
    The world`s only triple phase-changer PC in one case.
  6. #106
    Phenom™
    Sep 2002
    You need to dremel here to avoid that smd on the board.
  7. #107
    Apr 2005
    Backside shoot.. and air shoot! The card in the PCI slot is an Soundblaster Audigy2, fits like a glowe
  8. #108
    Apr 2005
    To sum it up:
    RAM-cooler = 430g
    Chipset cooler = 160g
    Asetek Micro = 300g
    ducting sys = 100g
    VGA-cooler = 350g
    HDD-cooler = 300
    Grand Total = 1640g
    Dead silent hardcore gaming riggz rules
  9. #109
    Technologically Challenged
    Aug 2004
    very nice. very good workmanship
  10. #110
    Apr 2005
    The big big plan of it all
    Fear my paintskills
  11. #111
    Xtreme Cruncher
    Mar 2005
    venezuela caracas
    i bought the icebergq4 pro for my a8n sli and temps are 32° is not dead silent but is pretty silent compared to my old chipset fan i had to dremel quite a bit and i can use my 2 vid cards it worth the change
    you can also unplugg the normal chipset and put a 80mm fan near it blowing air and it will work exactly the same very silent (i had a 80mm TT 22cfm temps were 33 32)
    Incoming new computer after 5 long years
    YOU want to FIGHT CANCER OR AIDS join us at WCG and help to have a better FUTURE
  12. #112
    Apr 2005
    To all of you that have been asking me about the messures of the chipset, here is a drawing I made in Paint
  13. #113
    INTEL inside
    Oct 2004
    Québec, Canada
    Quote Originally Posted by ArcticOC
    Nice work on those chipset colers
    could I ask you from wich cooler you got your big Rev.2.0 ? Thermaltake ?
    Thanks !
    Again...awesome work
    retired computer enthusiast
  14. #114
    Apr 2005
  15. #115
    INTEL inside
    Oct 2004
    Québec, Canada
    holy !
    you had to cut every fins !
  16. #116
    Apr 2005
    Quote Originally Posted by Supertim0r
    holy !
    Machined every fin that is aprox. 10 minutes of cutting in a circle saw designed for metalcutting
  17. #117
    May 2005
    Slovenia
    Here is my custom chipset sink build by me
    it might not be the best looking out there but it does the job ..
    Temperatures dropped from 54 to 43 @full load and Its still not finished im looking for a difrent fan that i´ll put directly on chipset ..
    (pic are bad quality coz my digital camera sux)
    here is what i´we done..
    Attached Images Attached Images
    i7 980x @ 4500Mhz 1.45V
    Rampage III Extreme
    6GB A-Data 1866Mhz+
    2x XFX 6970
    Crucial SSD 128GB M225
    X-Fi Titanium Fatal1ty
    Corsair HX1000W
    GSX-R 750 Rider
  18. #118
    Mar 2005
    Portland, OR
    Quote Originally Posted by Techwarrior
    So far from what I'm seeing the ICEBERQ4 PRO doesn't fit. You need the ICEBERQ4. I just picked one up today and I will try fitting it to motherboard. A lil dremel work must be done but nothing too hardcore. I really need to find my AS5 though.
    Ok so iceberq4 pro doesnt fit according to some people...ive been searching for this info for the last few days! What about the iceberq 5? looks like it has a much nicer HS but it sits way higher from what i can tell from product photos online. I assume no SLI with it either.
  19. #119
    Apr 2005
    Wales, UK
    Inspired by Dave.
    What i have now, lunaforce L4E
    Chilled PC UK - Watercooling Parts, Any Custom work undertaken including Laser Cutting (any parts, grills, side panels, brackets etc), Anodising, Powdercoating , Custom Spraying and Airbrushing, Fabrication, Watercooling Installs and more all done to the highest standard.
    International shipping no problem, even on Cases!
  20. #120
    Jun 2005
    it is much easier to do this: http://www.dfi-street.com/forum/showthread.php?t=9153
    dropped my temps from 55 to 41.
  21. #121
    Dec 2004
    Quote Originally Posted by saaya
    removing the termal pad and using some termal paste with the original cooler is already helping a lot afaik... dont know if a new heatsink is really needed...
    agree ! the other coolers dont look that better......but the thermalpad they use is horrible. Just remove stock NF4 HSF, use a razor/alcohol and remove the pad, insulate the surrounding area with electrical tape and put a thin layer of AS5 on the chipset. Re-mount the fan.
    Q6600 g0 L741 1.4V@35xx-> 8x44x FSB - 5:6 333/800- 2x2gb OCZ XTC Plats@53x mhz - dfi lp X38 TR2, Ultra Xtreme 120 - W7 64Bit - NV GTX275 - Corsair 520 (blew up) -> Toughpower 750W
  22. #122
    Apr 2005
    Only the ducting system missing now
  23. #123
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    Mutilated Alphacool NBX-N:
    You were not supposed to see this.
  24. #124
    Dec 2004
    WT...F this looks kinda cool
  25. #125
    INTEL inside
    Oct 2004
    Québec, Canada
    vapochill heatsink ?
