OCZ booster/IC7 issue, please help.
hello guys, i need urgent help here...
i've an IC7-G motherboard with an OCZ booster installed.
Bought some BH-5 memory to try it with the booster but apparently it seems that whenever i set the Vdimm at high levels (3.0v's or higher) prime95 will fail instantly with error code. That happens even at stock speeds (200fsb's).
I'm afraid that the booster isn't compatible with this motherboard or something... have tried the system running at low vdimm and prime95 runs just fine..., but it won't at anything higher than 2.9-3.0vdimm.
Anybody had the same problem and found solution , please post !
Thanks,
Byron
- You may not post replies
- You may not edit your posts
Forum Rules
