+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 49
Thread: Xtreme 1700+ JIUHB
    Xtreme Addict Cornelious0_0's Avatar
    Jan 2004
    Saskatoon, SK
    0
    Xtreme 1700+ JIUHB
    Just a quick question thrown out to you guys, I recently hit this as my max, somewhat stable OC on air. My 1700+ JIUHB is running on my Vantec Aeroflow, and in this Antec 1650B of mine, it's hitting up around 60C on load right now...very poor airflow...but she's still clockin' up as she is.
    What I'd kinda wanna do is switch from the NF7 over the the DFI Lanparty and get some h2O running on this thing. Even though you can't very well predict OC's...any ideas what this thing might be capable of if its doing 2.5GHz /w 1.875v on the Aeroflow with load temps of 60C as is? I'm very curious to try it out, this is one hell of a chip...and I really wanna see what it's capable of.
    Validated
    • Intel Core i7 875K @ 3.86GHz 1.35v /w Intel Extreme Tower Heatsink
    • Intel Extreme DP55KG
    • 2x2GB Kingston HyperX PC3-10666
    • ATI HD5970 2GB @ 850/1,200
    • Lian-Li PC-7B
    • Corsair TX750 PSU
    Dec 2004
    0
    What kind of budget are you on? if low, then high-end aircooling might be a better choice.
    Mar 2005
    0
    The DFI Infinity/Lanparty B is very limited Vcore wise, it won't give more than 1.85V stable without mods normally.
    Jan 2004
    Saskatoon, SK
    0
    Quote Originally Posted by Minstadave
    Ack, that might be a no go then, I had heard that it was the nicer board for higher fsb's...but if my vcore is cutoff that much then it might not be worth it.....but who knows, I wouldn't necessarily need this much voltage to hit these clocks if i got my h2O up and running on this thing.
    New results...I got a CPU-Z at 2,580 or so, but 2,515 was the highest I was able to grab a snapshot of SuperPi 1M...here ya go, I'm gonna try putting the comp in my deepfreeze like I did with my h2O cooled Prescott for some nicer results later today.
    Validation
    • Lian-Li PC-7B
    • Corsair TX750 PSU
    Jan 2004
    Saskatoon, SK
    0
    Update.....
    Just got done with my comp in the deepfreeze.....here are the new results:
    Highest CPU-Z: link
    Highest SuperPi 1M:
    I'm fairly happy with it for now...with the trial and error i got to do in the freezer...it's still temps holding me back. It's not worth it for me to pickup a Vapo just for this thing, but if I dropped a phase chance unit on this chip I have a feeling I'd slowly be nearing 3GHz...as at 2.689GHz I was idling at about 6-9C with a load temp of about 15-20C.
    Ah well, that's enough fun for one day, I tried everything i could, but the damn thing just wouldn't take me to 2.7 for a screeny.
    • Lian-Li PC-7B
    • Corsair TX750 PSU
    Xtreme Mentor
    Oct 2004
    0
    Quote Originally Posted by Cornelious0_0
    Phase change units are actually a lot more affordable than you think. A custom unit from chilly1 or pc ice can be had for a very reasonable price. 3GHz would definitely be a possibility if you were to travel that route.
    Best of luck!
    Jan 2004
    Saskatoon, SK
    0
    Quote Originally Posted by conrad.maranan
    Best of luck!
    Gah, now you make me wanna think about it....not fair.
    • Lian-Li PC-7B
    • Corsair TX750 PSU
    Xtreme Enthusiast Malachia's Avatar
    Aug 2004
    Milan,Italy
    0
    also i have one but mobo is stuck with multiplier at 12.5 and old nforce2 won't pass 210fsb....i need a dfi nf2 to get 3ghz and more
    Xtreme Enthusiast SnipingWaste's Avatar
    Oct 2004
    0
    I had a 1800+ JIUHB that did 2.4 gig at 1.6V on air. The main thing with the JIUHB is keeping the temps down on it. Here is a funning thing for ya'll, I did this with a vmoded ECS L7S7A2 SIS 746 mobo.
    XS_THE_MACHINE [XC] moddolicous's Avatar
    Nov 2004
    Long Island
    1
    Definetly get that under somthing colder than just 6-7 degrees. I have a feeling that with Mach GT you could probably get 3ghz. As far as the cpu voltage & multiplier goes, try this website. Just choose your core and other stuff, and it should help.http://www.ocinside.de/go_e.html?/ht...md_pinmod.html
    "Victory is always possible for the person who refuses to stop fighting"
    clicks to save kids
    Jan 2004
    Saskatoon, SK
    0
    Quote Originally Posted by SnipingWaste
    Very impressive dude, the clock's nice...but I'm talkin' about the welfare ECS board you did that with.
    • Lian-Li PC-7B
    • Corsair TX750 PSU
    My own little world InSanCen's Avatar
    May 2005
    The Septic Isle
    0
    3GHZ can be done with Water. My mate FatRakoon hit 3Ghz with a crap watercooling, (But managed to solder a stick of Corsair in his NF7 doing it ). Total Suicide run (In it's truest form, Dead board, Dead RAM, but the chip LIVES!) Chip was JUIHB DLT3C 0304, got a screenie of it somewhere... (Quick rummage around HD & Upload)...http://img100.echo.cx/img100/7338/xp173ghz0nh.jpg
    My JUIHB DT3LC 1700 (0310) is at 2.5Ghz for daily use (on Air, SI97, 172x50mm Papst, 80mm Delta). Still aint found max, as I'm waiting for an OCZ Booster.
    Depends on the chip really.
    Quote Originally Posted by JF-AMD View Post
    Dual proc client systems are like sex in high school. Everyone talks about it but nobody is really doing it.
    Jan 2004
    Saskatoon, SK
    0
    Very nice indeed....I'm not looking to go after any TRUE suicide shots like that....but I would like to see what it's capable of. I'd be interested to see this chip even with a nice Thermalright heatsink and a 'nado runnin' on 'er...just for comparison, and getting the CPU out of my 30C case temps would also help.
    All in all I want to give it a go eventually, can't say when but I'd like to get the NF7-S fully modded and have some form of sub-zero cooling running on my JIUHB DLT3C.
    • Lian-Li PC-7B
    • Corsair TX750 PSU
    May 2005
    The Septic Isle
    0
    Try this Thread
    http://www.xtremesystems.org/forums/...ad.php?t=61669
    I'm at 225*11 on a JUIHB DLT3C 0310, 38c Semi-Load (Just surfing net, writing emails etc...), 33c Idle in WinDoze
    What stepping & week is your Chip?
    Jan 2004
    Saskatoon, SK
    0
    thx for the linkage.
    • Lian-Li PC-7B
    • Corsair TX750 PSU
    Feb 2005
    Waterloo, Ontario
    0
    Amazing clocks guys, especially for such an old chip!
    3500 clawhammer @ 230x11 1.7V
    Foxconn geforce 6150
    x800gto @ stock
    2x512 mismatched sticks in dual channel
    Black case of godliness
    Xtreme Addict don_vercetti's Avatar
    Jan 2005
    Oxford, UK
    0
    2.6ghz is my max for a JIUHB DL3TC. I reckon that once you get to about 1.85v or so, temperature starts to become a big issue. I can't ever afford to get phase change or anything like that (althoug how much does chilly1/pc ice sell them for?) so the coldest i can get is during winter, windows open, etc.
    I know it can give higher though, just need to wait until next winter.
    Conroe E6300 ES
    2x1gb Ballistix PC8000
    Asus P5W DH Deluxe (1705)
    Manli Geforce 7950GT 512mb
    Hiper Type-R 480w
    Samsung SP250
    "What did the quantam duck say?" "Quark Quark"
  18. #18
    Xtreme Addict Bennah's Avatar
    Jan 2004
    Manchester (UK)
    0
    PM chilly1 or PC ICE for prices. It depends on specifications. I dont know how many things Ive said this
    Another old skool overclocking thread. They seem to pop up all over the place now
  19. #19
    Fused tictac's Avatar
    Dec 2003
    Malaysia
    0
    Very nice ... i have problem running my tbred b over 1.93v
    My best( December 2003) arround...
    2529MHz @ 1.93V
    JIUHB DLT3C 0322XPMW
    Watercooling
    Stock NF7-S Rev2.0 + D10 Bios + L12 Mod
    Single Channel ... samsung TCB0 @ 2.5-3-3-11-T
    [ur]http://www.tictac.katrourke.com/pic/tbredb-1700+-jiuhb-0322xpmw-2530MHzi.gif[/url]
  20. #20
    May 2005
    The Septic Isle
    0
    Nice. What BIOS were you using? I'm debating about flashing mine (can't quite bring mysef to keep a Floppy in the system... UGH!), wanted to know your thoughts on the best for Dual Channel (This rig is a Daily runner as well, I just crank it right up from time to time).
  21. #21
    Jan 2005
    Oxford, UK
    0
    you dont need a flopy to flash nf7...i forget what you can use, off the top of my head, but no doubt tictac can tell you.
    I remembered, it's Flashmenu, and i recall hearing that you should use v1.24 for best results (correct me if i'm wrong, this is all off the top of my memory).
    And bennah, i was just asking for a rough price, there isn't a cat in hells chance of getting one. But the most basic type he would have to offer, if you wish to be picky.
    Conroe E6300 ES
    Hiper Type-R 480w
    Samsung SP250
  22. #22
    Xtreme 3DMark Addict Geforce4ti4200's Avatar
    Sep 2003
    0
    very nice oc, I used to own an xp2000 that did 2.2GHz at 1.85v and 2.4GHz at 2v. those cpus sure ran hot
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
  23. #23
    Xtreme Member BigDov's Avatar
    Jun 2002
    Portland, OR
    0
    This makes me smile My old JIUHB used to be pretty happy at 2.3ghz with about 1.75v...... and now it's being under-utilized in my wife's computer at default clocks and voltage LOL
  24. #24
    May 2005
    The Septic Isle
    0
    I know, I've got a 1700 JIUHB DUT3C sitting in the GF's comp. The thing looks nice, but that's it. Nforce Chipset (basic Gigabyte Mobo though, UGH!), 2x256MB TwinMOS PC3200, and she plays bloody Mahjong!!!
    Grrrrrrrrrrrrrrr
  25. #25
    I am Xtreme massman's Avatar
    Jan 2005
    0
    my 1700+ jiuhb 310 get too hot
    but I think it's a good chip, because it gets 2200 MHz. suicide at 1.7v
    verified
+ Reply to Thread
