Results 1 to 6 of 6
Thread: CBBID and -40c
    Jan 2004
    Ogden, Utah
    CBBID and -40c
    Comon guys, why do people say they dont work under phasechange?
    K8NS-Ultra 939 most likely the board is toped out @ 2.6.
    BIOS F5
    CBBID 0451 EPMW 3200+
    chilly1 extream
    OCZ 520
    GF 6800 GT
    OCZ VX 3200
    Raptor 1
    Going to try my DFI UT SLI-DR, BIOS 414-2 later today to see how it dose.
    I'v got another good CPU here. It's CBBHD 0449 MPM 3000+ .
    I bet almost every AMD cpu works under pasechange. But who knows
    I'll post my DFI results in this thread. Unless the mods dont mind me making another one.
    Peace Nugz
    Jun 2004
    USA, Vermont
    Yeah even a CBBID should do over 2.6...mine did 2.6 with 1.68...not for very long as it burned out AT STOCK!!!...it has something to do with the mem controllers and the cold and no not ALL suffer from it it is luck of the draw...
    http://smbach.com/mad.gif
    Opty 175 Rig
    Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
    AM3 Rig
    Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
    DFI NF4 BIOS Guide
    Jan 2004
    Arlington, Texas
    yep not every cpu has cold bug, hell allot of venices have cold bug but not all AMD is actually trying to fix this, im just wondering why clawhammer cores don't have cold bug, must be a problem when moving down to 90nm
    "each driver release plays whack-a-mole with a few more annoyances" -inq
    Xtreme Cruncher
    Mar 2005
    venezuela caracas
    try it -100
    Incoming new computer after 5 long years
    YOU want to FIGHT CANCER OR AIDS join us at WCG and help to have a better FUTURE
    Feb 2005
    Team MXS - GA,Atlanta
    Mine , CBBID 0507FPAW is doing 2750MHz @ 1.80V rock stable so far with Vapo LS . Give it more volts
    Jan 2004
    Ogden, Utah
    Tops the K8NS-Ultra-939 will do it 1.70v witch is like 1.67v-1.65v with a DMM
    Just installed my DFI UT SLI-DR NF4 and well one stick of OCZ VX works but one don't. Only the top 2 DDR slots work in single channle. Yes just 1 yellow and 1 orange slot works. Not together. The bottom 2 don't work at all single channle or dual with my vx.
    Thro 2 GEIL PC4000 2x256 in just orange slots and works dual channle. 512mb tho. Umm But both VX work in the Gigabyte board. umm
    Got this DFI @ single channle 270 (2700mhz), 185 mem diveder 245 ram, 4xhtt 1080x2 Not 3x, 1.40v +133% in BIOS, 414-2 BIOS umm
    DAM either a DFI RMA or OCZ RMA
    Peace Nugz
