+ Reply to Thread
Results 1 to 10 of 10
Thread: Which CPU is better?
    Mar 2005
    0
    Which one of these two cpus is the best for overclocking?
    P4 2.8Ghz : Cpu 1 Or Cpu 2
    Registered User LanoX's Avatar
    Oct 2003
    0
    Quote Originally Posted by Gorgeous
    CPU1 is Prescott cpu and its all right but it can get very hot if you want to overclock it .I got P4 2.8e and my cpu is doing 4.1 not stable, and on air its doing 3.5 stable.
    The other cpu from what i can see its normal Northwood cpu and not sure how good is with overclocking as it’s all a gamble . i would go with CPU2 but again that is just me .
    .::::. Intel 2.4c @ 3.8Ghz || Asus P4C800-E Delux || 2 x 512 OCZ PC3200 Plat Rev 2 || Sapphire Radeon 9800 Pro Flashed to CT || Samsung SyncMaster 172X || Prometia MachII .::::.
    Xtreme Addict Gray Mole's Avatar
    Apr 2005
    Closer than you think.
    4
    I like the hyperthreading, but that's just so you could fold 2 clients
    If you do a lot of worksation type stuff then hyperthreading can be better...
    If not, and you just do gaming and such, then hyperthreading isn't really that much use...and can give you grief at times...
    The 2.8 non HT is a 1 meg cache, and it's a 90nm process...likely will oc better if you want it to...
    Newer technology, better chip so if hyperthreading isn't something you need, then cpu no. 1 is the better of the 2...
    Oh yeah...the no. 1 is gonna run hotter and all that, so you'll need to keep in mind that upgraded cooling would be advisable...
    Gray
    Mar 2005
    0
    Quote Originally Posted by Gray Mole
    Gray
    Hehehe...i'm going to be using this as a folding machine,i best go for the HT one then...
    Edit : They both have hyper threading....
    Xtreme 3DTeam Member
    Jan 2004
    Cascadia
    0
    #2 might not be that bad. Every once in a while a good D1 cpu pops up....
    Last summer, I found a SL6WT that did 3.91Ghz on air @ 1.64-1.65 volts. Used it that speed 24/7, until November.
    Official ORB bottom feeder.
    Mr Fantasic ibby's Avatar
    Apr 2004
    0
    get HT presccot
    Bulletproof Lithan's Avatar
    Jan 2003
    Shun low, K?
    0
    2.8 Prescott - never owned
    2.8 D1 NW - Owned three, one I never tested, one did 3.3ghz, one did 3.75ghz
    Only the stupidest humans believe that the dogma of relative filth is a defense.
    INTEL inside Supertim0r's Avatar
    Oct 2004
    Québec, Canada
    0
    cpu #1 is a "C0" revision = really bad oc
    you should at least try a "D0" or get the northwood
    24/7 PC : Biostar Tpower P45, E8400 E0 @ 4.4ghz, 4gig G.SKILL F2-8000CL5D-4GBPQ, Asus 8800 Ultra, Corsair HX520w
    benching stuff : P5K Premium, DFI LANParty Dk P35-T2RS, XBX2 <3..., few "D9" kit, few Q66 ES / E8400 / Q9550 ES, 8800GT and GTS, OCZ PS600W, Zeus 750w, Phase change, Tuniq, Ultra 120E...
    Apr 2004
    0
    get a newer version of the 2.8 pres
    i had 2x 2.8 northwoords, which both stopped at
    3.3 / 3.4
    the pressey stopped at 3.4/3.5 (air cooling)
    Xtreme Enthusiast IluvIntel's Avatar
    Apr 2005
    Melbourne, Australia
    0
    Gray
    I game on my rig and its smooth as silk, also doing distributed computing project - BONIC cp.net. simultaneously. Playing HL2, DOOM 3 or FarCry, all very PC stressful games @ high res.
    Never had grief with HT before.
    Signature? are you kidding? with new stuff coming out every day, why bother ?
+ Reply to Thread
