+ Reply to Thread
Results 1 to 7 of 7
Thread: epox 8rda+ multplier perfomance anomaly
    Oct 2002
    germany
    0
    my new epox 8rda+ behaves strange if i select multplier under 10
    with multiplier under 10 i get 2960mb's with sandra membench
    @200fsb with sync dual channel (2-4-2-2 timings).
    with multiplier 10@ 200fsb i get over 3100 mb's!!!!!
    i tried all three bios version which are available and all have the same anomaly
    can anyone explain this???
    another guy posted the same problem @ aoaforums!!
    Xtreme Enthusiast Alexandrus's Avatar
    Dec 2002
    0
    Weird, maybe the multiplier also changes some registries that affect the memory performance. Try using WPCREDIT to check if any registries change.
    Oct 2002
    germany
    0
    Xtreme Member SKATAN's Avatar
    Jun 2002
    0
    does the problem ocur if you use multi 9x instead of 9,5x ?
    Barton mobile 2500+@2500mhz (slk900U) 11,5x218 2/2/3/11 1gb (2.96v) 256mb infineon 2700 c2.5 + 256mb corsair 3200 c2.5+ 512mb patriot 3500 c2 (salada total na 8RDA completamente alterada )
    ATI 9500 + artic-cooling vga silencier + rivatuner patchscript = ATI 9800PRO (xt clocks coming soon)
    resumindo é a chulice TOTAL :x2:
    Jul 2002
    Italy
    0
    same problem here, also trying to change registers with wpcredit doesn't work (i think those registers are read only)
    Xtreme Member spaceboy's Avatar
    Jun 2002
    0
    sounds EPOS
    Oct 2002
    germany
    0
    i tried several multis, all multis under 10 have poor performance.
    multi 10 and above have great performance.
    this happens @ all fsb i tried
    another problem i have is, that if run 200fsb sync ram my cumputer doesn't boot if i cold start it.
    before it runs 5 hours with no problem @ this settings.
    only cold boot have this problem!!!!
+ Reply to Thread
