+ Reply to Thread
Results 1 to 5 of 5
Thread: How do i check the voltage?
    Xtreme Member kappa2001's Avatar
    Aug 2004
    0
    So i'm a total noob at vmods and i want to vmod my 9800pro.
    could anyone tell me how to read the current voltage (not vmodded) in it?
    Member Holst's Avatar
    Dec 2002
    Leics UK
    0
    Do you have a multimeter?
    Aug 2004
    0
    Quote Originally Posted by Holst
    yes of course :p
    Dec 2002
    Leics UK
    0
    http://www.maximumoc.com/img/hardwar...ltage_mods.jpg
    Top right of that pic you see the green mark for "vgpu monitoring"
    Put the + lead from your multimeter there.
    Put the - end onto the PCB where the PCI bracket screws on.
    Set your multimeter for volts.
    Be VERY VERY carefull when putting the probe onto the PCB, if you slip and short somthing your card WILL DIE!!!!!
    So watch out.
    Aug 2004
    0
    Ok thanks a lot
    I'll try that tommorrow when i have the time.
    Thanks once again
+ Reply to Thread
