I've read up on mods for the mach1, but I'm not sure whether it will be enough to handle my Prescott. How much would the appropriate mods cost? What skills do I need to do them myself? Would I damage the Mach1 if it ran at 0c?
University of Florida Graduate 2005
CPU: Q6600 @ 3.55Ghz @ 1.52v bios lapped
MEM: Crucial Lan Fest 2x 1GB DDR2 1185 @ 2.275v
MOBO: IP35 PRO Hacked W/ heat pipes modded using MX-2
PSU: 600W POWERSTREAM
GPU: 8800GTS 602/908
COOLING: Thermalright Ultra Xtreme - Lapped - 2x 12CM S-flex
Thermal Interface: MX-2
Case: Cooler Master CM-690 5x 12CM Fans
OS: Vista, XP, Ubuntu
You will not damage the mach1 by running 0c as long as the compressor doesn't get to hot.
My Mach1 is refilled with R507 and i reinsulated it. Turning of the heating in the head and running the fans on full when you are benching or even putting higher RPM fans on it helps a lot.
Then it will be able to handle 200w for sure
ran a 2800mhz barton @ 2.28v at -39c (real temp, checked it with DT200)
Pifast:
Socket 754 3700+ Clawhammer action:
39.64sec 11*285 2.5-3-3-7
Now Pifast @ 3306MHZ !!! 37.72sec World record!
Now SuperPi 1M @ 3306mhz 26.922sec World record!
Ministry of Overclocking Contests
Do you need to mod a Mach1 to handle a Prescott? I don't think so. We had a 3.2E running dual prime @4.0GHz with a unmodded Mach1 without any problems.
should be no problem
i have a system on a vapo se 12volt cooling my ic7 max and prescott 3,2 at 4 gig
so a prom should have no problem
How hot is too hot for the compressor. I just ran my mach1 for 20min and the compressor was getting hot. I could hold my hand on it but it was on the hot side of harm.
Is it ok to run unit without any load at all.
for how long. I wouldn't want to for more than 15-20 sec. I'd feel pain but I don't think its hot enough to burn flesh
The outside of my compressor is 50 - 52 celcius , measured with a cheap tempbrobe that i stick on it with some tape
Is this ok ?
Its a Mach 2
CPU : Intel Core 2 Extreme QX9650
MB : Asus P5E X38 Rampage bios
RAM : Team Xtreem 4x1GB DDR2 OPB handpicked
VGA : Sapphire 4870
Power : Antec Quattro 850w
Storage : 1 x 60GB OCZ Vertex + 2 x 750gb WD 32Mb
DVD : Samsungs DVDwriter Sata + Liteon DVD
Sound : Creative XFI Xtrememusic
Cooling : D-Tek Fusion + D-Tek Fusion GFX
Monitor : Samsung 226BW
Errorcode : An error occurred at address AC 20 DE AE FF BC ...... System halted.
Comperssors like the heat, the oil dont though. Not sure what the limit would be on your oil but I think its in the region of 120ºC So you should be fine
Sounds like you will be fine.
Mach 1 gets pretty cold without modding. Wouldn't hurt to add a fan in front of the condensor and make sure that you have the side panels on the prommie....
Hopefully Chilly1 will step in and give us some input.
I sure would hate for you to ruin your prommie...
On the side of the compressor it says that it is thernally protected
Cool. Highly doubt any manufacturer would just allow their compressor to burn itself up.Originally Posted by yasoumalaka
Thermal protection is a must have.
Chilly1 will mod the compressor for you if you are interested. I know the price, however, that is something that should be discussed with him through a PM.
Take care
I might just do it myself. Thats how I do everything else. Its not the best way to avoid a headache but I worry about shipping it. No offense to any one but ups fedex dhl, they all suck. I bet they would set it on the side throw it around bang it up and then act stupid like nothing happend and blame it on me. It really makes me nervous to ship it. I'll just read up and do the mods myself then I might ask the local air conditioning place to fill it so I don't have to pay for 25 pounds of refrigerant. If not that I'll get certified. Pretty soon I'll graduate from college and hopefully I'll be able to afford 25 pounds of each kind. Then I might wip up a special blend or something crazy. LOL!!!
Yeah some ship couriers really have total disregard for the safety of their customers belongings.Originally Posted by yasoumalaka
I wonder how many employees use the use the courier that they are employeed with when they order something...and if it's broke when it arrives, how they feel about it.
Good luck with doing the mod yourself...
