You don't have to buy expensive hardware to bencome an Xtrem Legends, our 3D Team Capitan do wonders with unexpensive hardware ..please welcom Charlie in the Hall of Legends
hey charlie, nice to see you had time to come check this new place out as well
dry ice is next to the mini bar at the right have fun
That's just toooooo cool...
THX! Guys....
C
4.5ghz on air!! What would you expect? Nice o/c, btw.
hey charlie, does your x800xl have a power plug?
nope, no plug and 2.0nS memory... the "crappy" BBATIOriginally Posted by saaya
C
Hey there Capt'n!
heh... id like to play with one of those x800xl cards with a power plug, i hope the power plug gives it a nice boost when upping the vcore... i have a feeling the x800xl sucks up quite a lot and is close to the max the pciE slot can deliver, and without a power plug vcore probably gets unstable when increased and the vpu is oced... thats at least what i HOPE because then a card with powerplug would oc better heheOriginally Posted by charlie
btw, what memory did you order? tccd not performing on the 865 isnt something new, but bh5/bh6 not clocking high is odd...did you try eb or ballistix yet?
my bbati is the highest OC'er out there... on DI @ 1.7v, 550/615....
When I get the P4 ironed out, I'll bench Intel+x800xl....
Yeah, odd thing... tccd/5 sucks...the BH6 sticks are only goood for like 235ish..
I have MUSHKIN HighPerf PC4400 coming, guaranteed 275 2.5-3-3 on teh 865...
C
oh cool, mushkin has 865 tested sticks?
and 550 on an x800xl is amazing
is there a big difference between max mem and max core clock between just ocing core/mem and ocing both? if yes then the card prolly pulls a lot of power but it cant get enough through the pciE slot...
These mushkin sticks are really nice... this Intel rig is my new 24/7 beastie
I'm running 24/7 super smooth and stable @ 4100mHz+ 274mHz (1.41v), 1:1, 2.5-3-3-5, Mem perf mode enabled, everything else tight as can be...
Pulls 31s sPi, pretty much the same or better than my 24/7 3000+ rig...
And economical, too! Mobo @ $46, CPU @ $230, DDR @ $230...
Yeah, on DI, the X800XL wakes up and starts running! Woohooo!!!!
I'll try that test of the power through the pci-e slot!
I'm HAPPY
C
so you decided to go for the p4 rig already?
Well, I didn't say THATOriginally Posted by saaya
my next "competition rig" will be 90nM FX... San Diego!
lol... but it's replacing my old P4 2.66B @ 3.4gHz on IC7-G... so the new rig is considerably FASTER than the old one....
C
hmmm you picked a bad time to update your desktop rig
dual cores and the san diego are just around the corner hehe
im sure the dual cores are great for desktop rigs if your multitasking a lot...
