ok well im still "aqurering" windows xp and i wanted to know what linux os would be the best to use in the mean time.
I will only be overclocking no games or nothing,
D2OL will be on and off this summer due to heat
man, i thought i was wierd, and then i started hanging out here at Xtreme Systems-Disposibleteen
Rig1-Sempron2800+,ABIT NF7-S REV 2.0,Radeon9200se,No-Name350watt PSU,
Maxtor80gigs harddrive,K-Byte 256mb pc2100 & Ultra 256 pc2100 Ram, No-Name CD-Rw Drive
I like SuSE, but really any distro should work fine. Check out the suse linux ftp servers, you can get a copy of SuSE 9.1 personal.
jjcom
I don't think you'll find that any distros are better than any others strictly for overclocking. Just use whichever one you like best.
ok thanks shall try suse
There's no best distro for overclocking, it's all a matter of taste. I am, myself, a Debian guy. But yeah, SuSE is definately worth a try.
Gentoo :P
But Gentoo takes too much of a time to compile...
I'd go with Mandrake, or Suse.
Try VidaLinux OS. Its Gentoo but without all the hassle. http://desktop.vidalinux.com/Originally Posted by shadowing
Cya.
SuSe 9.3 should be out mid-april with lots of improvement. I Agree with Perkam, SuSe 64 bit all the way!!
Core 2 Duo E6600 [L625A] 3330MHz 1.375Vcore 24/7
Core 2 Duo E6600 [L640F] 3330MHz 1.475Vcore
Crucial 10th Anv 2 x 1GB DDR2-667 @ 463MHz 4-4-4-12
ASUS P5B Dlx
FOTRON BLUE STORM 500W
TT BT with stock Fan
Gigabyte Nvidia 7600GSw/ Silent Pipe
WD Cavier 250GB
Antec P160
There's only one flaw with Suse. It uses the ReiserFS system. The ReiserFS is pretty unstable...
fedoracore 64bit edition, apparantly thats rather good
Yeah, I lost faith in ReiserFS a while ago when I lost an entire partition suddenly and could never recover it. Now I'm sticking with the old, slow, and reliable Ext3.
Can't you choose how you want the drive formated? I know you can choose in 9.0, did they change it in 9.1 or 9.2?
jjcom
i too am converting back to ext3. i keep hearing of problems w/ 2.4 and reiser. now, the reiser package for debian requires 2.6.Originally Posted by masterofpuppets
one of my disks lost its reiser journal/index in a reboot. a quick repair put everything into one directory...all 110gb of it. i restored/reorganized what i didn't have elsewhere and restored the rest from another box (redundancy rocks! )
Slackware was stable more so than windows on my last system when overclocked. I agree about using ext3 or maybe ext2, most other file systems I've tried tend to bug out with overclocking when you hit higher clocks.
Winchester 3000+ (CBBHD 0448 SPAW) @ 2.6GHz 1.440 VCore
DFI LP NF4 SLI-DR
GSkill LE 2x512MB @ 290MHz 2.5-4-3-7 3.0VDIMM
ATI Radeon X800XT @ 540/510
PCP&C 510 Deluxe SLI
All Stock cooling
Saitek Gaming Keyboard + Razor Diamondback Mouse
Anyone tried Fedora Core 3 for O/C and running folding@home? I'm trying it out, once I get all the updates for the home desktop version on 2nd PC sig spec machine. (see below)
Signature? are you kidding? with new stuff coming out every day, why bother ?
I found something out...in SuSE, 2.16ghz is stable, but in Windows, 2.25ghz is stable and my D2OL output on that rig goes up.
jjcom
Debian
RED HAT 9.0 by far the best linux i've ever used. and i have been using linux for a few years and i've tryed all of them from debrain all the way to suse to yellow dog. red hats just stable easy to use and a good software bundle in general.
my cs server:
amd xp 2600
abit nf7s v2 with vmods
ati radeon 9800 xt
hyper x pc3500 2x256
ttgi 520 psupply
eheim 315 gph pump
dangerden nbridge&GPU block
x-flow (modded) cpu block
lian li pc75(black)
running stable every day use at 2446@10.5*232
I disagree. It's terribly out of date from the box, uses a 2.4 kernel (ARGH TEH SLOWNESS), and is from Red Hat (who I hate with a passion).
I agree. I prefer Debian or Slackware.Originally Posted by masterofpuppets
Gentoo has grown on me alot. Just done a stage1 install on my Pentium II! took hours to bootstrap!!!
Out of all the distros I have tried I have never tried Gentoo.
hi.
try this: http://distrowatch.com/table.php?dis...on=overclockix
fedora core 4 works for me.. came out the other day..
