+ Reply to Thread
Results 1 to 12 of 12
Thread: I killed my Start button
    Registered User Mime's Avatar
    Nov 2002
    Silicon Valley's Backyard
    0
    Ah the wonders of hex editors.
    Blark is a word I created.
    http://www.winguides.com/registry/display.php/791/
    Do not meddle in the affairs of archers, for they are subtle and quick to anger.
    My skeletons are in my computer not my closet.
    JBELL
    Guest
    I edited my WinXP and it says ''XtremE'' now
    Registered User Attitudx's Avatar
    Feb 2002
    Oklahoma
    0
    mine says attitudx, thought about changing it to idiot, freak, uptolate you know something short maybe just XS
    So many tricks & so many lies
    Too many whens & too many whys
    Nobody's special, nobody's gifted
    I'm just me, warped & twisted
    MY HeatWare
    Registered User firegate's Avatar
    Dec 2002
    Santa Cruz, CA
    0
    back in high school, a friend of mine edited all of the computer lab comps to say fart instead of start.. I think they're still that way because they cant figure out how to fix it and dont want to reformat..
    Banned shray's Avatar
    Oct 2002
    0
    Mine now say STOP!
    Xtreme Member theonetheycall's Avatar
    Nov 2002
    Los Angeles
    0
    I changed mine a couple of times and sometimes it works and sometimes it doesn't
    2400+ @ 2100Mhz
    210x10 1.65v Everyday use.
    Watercooled.
    256MB Corsair XMS3500C2 2-2-2-11
    I am lame Smizack's Avatar
    Dec 2001
    0
    Well, if you have XP Don't friggin use Sp1! It killed my beautiful start button, and I really don't wanna format again.
    But I think I'll have to.
    Nov 2002
    0
    I had it not work a few times also, was forgetting to change my registry to point to the edited exe. It didn't seem like it should be causing a problem, but it did. ::shrugs::
    Nov 2002
    0
    Heh, funny you said that, cause the first time I changed mine I changed it to "Fart!", but decided Blark was a better fit this time around.
    Dec 2001
    0
    You dont' need to change the registry. Just edit and delete a few files. At least under XP. All others are a differant story, but I never got into hex editing. I wanted more letters.
    Banned Johnny Knoxvill's Avatar
    Nov 2002
    0
    Nov 2002
    0
    If you'll allow me to quote myself...
    "Blark is a word that Mime invented a while ago probably while severely sleep deprived and suffering from overexposure to Perl. Needless to say blark doesn't have any one specific meaning(in that state not many things do). "
+ Reply to Thread
