Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 79
Thread: 10 heatpipe xp120
  1. #51
    Mar 2005
    Ontario, Canada
    I would like to put a third opposite the vertical one and find a way screw it to the board for better contact.That would be 328cfm+/- and loud.
    I also thought of two silent towers, and I like the look of the hyper6 but bet its heavy.
    The second xp120 only got me 9C lower I dont know what a third would give.Also thought of the vertical xp120 and the silent tower / nitrogen combo as one unit, that would be heavy.
    $60 for the third and 270fsb would not make a $400-$500 water system for another 7fsb(277fsb is the boards max) very practical.
    Rampage III Gene I7 950@4.48G--1.485V HR-02 12G G.Skill 1600-1.5V, GTX470-SLI@725core 1750mem, Antec P180 MINI
  2. #52
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    9C is _VERY_ nice as XP120 is already xtremely efficient. Is it possible to put one more on the other side (i.e. is there room?)
    Xtreme all the way!
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
  3. #53
    Jan 2005
    Texas
    Quote Originally Posted by IvanAndreevich
    Xtreme all the way!
    Yeah, a 9C improvement is uber own4g3
    Got news? Post it HERE
  4. #54
    Mar 2005
    Ontario, Canada
    In answer to fan direction the one on the back of the case is exhaust and the other is blowing down on the fins.I tried the bottom one upside down and there was no change in temps but the fets and caps on the board got about 15C hotter.The Vcore droop was the same.
    Also the base will not mount 180degrees without grinding or I would have tried both fans blowing on the fins and a 3rd 120 on exhaust.Thermalright claims only a 1degree difference between suck and blow but I might get better flow with one side open on the fan .I dont want to cut a 120mm hole in the back of this case yet.
    Yes ther is still room for a third, also mabye an xp-90 at 90degrees above the northbridge once I change the way it mounts.
    WTF,I might as well go as far as I can without water.
    And I hit the board with a screwdriver removing the hsf and half removed a resistor. Had to solder it back on so there is no warranty for this board anymore so its droop mode time.
  5. #55
    Aug 2004
    Lindenhurst, NY
    What? A XP-90 onto the two 120s? Thats crazy, it'd be awesome though.
    -AMD 64 3200+ @ 2.4GHz
    -MSI K8N Neo2 Plat
    -1GB Patriot 3200XBL TCCD (2.5-3-3-6)
    -XFX 6800 AGP Unlocked
    -OCZ Powerstream 520W
    -2 Western Ditigal WD800 SATAs
    3Dmark01
    23,142
  6. #56
    Nov 2004
    uNd3rgr0uNd
    is it loud? i mean damn..
  7. #57
    c[_]
    Nov 2002
    Alberta, Canada
    how about 4 (vertical) XP-90c's in a "square" with an XP-120 mounted on top of them in the center? lol
    Could mount a fan on each blowing towards the center.. hmmmmmmm.....
    All along the watchtower the watchmen watch the eternal return.
  8. #58
    Mar 2005
    Ontario, Canada
    Well, it would be 3 xp120s, 1 front, 1 back, 1 top and the xp-90 on the northbridge side in the middle. that might get a little heavy.
  9. #59
    beefin' it up!
    Dec 2004
    WPI
    no such thing as too heavy!
    go for it :P
  10. #60
    Feb 2005
    Ottawa, Canada
    i have got to see that monstrosity in the works! lmao 4 heatsinks on a single cpu. now thats intense. 19 heatpipes!!!
    Athlon 64 3200+ Venice
    DFI NF3 Ultra-D
    BFG 6800GT
    Mushkin Redline XP4000
    Cooled By XP-120
  11. #61
    Mar 2005
    Ontario, Canada
    Well I,m at 270fsb(4.32Ghz)@ 1.725Vcore and it ran dual prime95 and atitool find max memory for three hours error free but as you can see by the picture it started to throttle about 12% at about 15 minutes. It doesnt get that hot gaming so I will try an hour or two of ut2004 later.Cpu-z always reports the wrong voltage.
  12. #62
    Feb 2005
    NY
    Quote Originally Posted by SuperDude
    your gonna rip your board off, rofl
    nah, xp120s are 350g, so x2=700g, still less than a hyper 6. Btw!!! that is ing awesome. Ill send you 2x xp120 and do that for me
    Unapproved link in signature. Signature has been removed.
    Please read the forums rules and guidelines. They are at the top of the forums.
    Edited by IFMU
  13. #63
    Mar 2005
    Ontario, Canada
    Time for an update.
    yesterday I used a smaller than normal drop of AS5 and my temps at 4.24Ghz at 1.6Vcore are now 53C at full load, dual prime95 and atitool running with fans on low!!
    I then attempted 4.32Ghz again and got a half an hour at 1.7Vcore with no throttle but one prime failed shortly after.
    http://client.webshots.com/photo/312...12256144CHylAK
    Today with some changes in the bios I ran 4.32Ghz at 1.675Vcore at 59c for an hour with dual prime and atitool and no errors and no throttling.
    I decided to try 270fsb(4400mhz) at 1.72Vcore and it ran but with about 20% throttling. I dont know yet if it will game at that speed witout throttling.
    http://client.webshots.com/photo/312...13366440DFcivH
    I hope the links work.Clik on normal size to see clear picture.
  14. #64
    Nov 2004
    DK
    In the chilly Scandinavia all you would need on that thing is a 500mm fanduct sucking in 2C air from outside attached to the side...
    My God!
  15. #65
    Nov 2004
    Somewer Hot n Humid
    tats extreme...n its so huge
  16. #66
    Apr 2005
    3095.au
    Man that is freaking awesome.
    I wonder how it'd perform though, if you could actually attatch all 10 heatpipes to the same base?
    Currently Tweaking ..
    DFI nf4 Ultra-D R.AD0 w/704-2BTA BiOS ::
    CACJE 0603 FPMW Opteron 146 ::
    2x 1GB Mushkin xp 4000 UCCC ::
    GeCube x1900XTX ::
    12,993 ::
  17. #67
    Mar 2005
    Reykjavik, Iceland
    1) fordf250, What are your amient / room temperatures?
    2) Wouldn´t fitting a 3rd XP-90 or xp-120 just make the base to thick? That way trapping some of the heat in that huge block of copper?
    3) Wich was it, does AL dispatch heat faster but Copper... or what?
    **edit**
    3) AL does dispatch heat faster than copper...but copper absorbs heat faster from the source.
  18. #68
    Mar 2005
    Ontario, Canada
    skuliaxe,
    Yes I thought the same thing and since I like the results I got with 2 I left it at that.I think the most heat is pulled from the center and as you get closer to the outside it makes less of a difference and mabye why water blocks are so small and the water is sprayed right down the middle.
    My room temps are around 22-24C.If I open the window on a cool day 16-18C the cpu temp only goes down 1-2C even when its to cold for me to sit beside it.
    I dont know about al vs copper but the base is cast copper and very thin where the pipes join the base.
    I have an infrared lazer thermometer that I use to check temps of thing that dont have sensors.
    I can see the base of the heatsink when the side door is of so here are the temps at the side of the base.
    When the cpu is at idle 28C in hardware monitor the base is 30C.
    When the cpu is under load at 56C the base is 34-35C at the edge.
    Under load the fins are between 30-40C.I dont think ther is much of a way to improve on that.Also the fans on full and the fans on low dont make that much difference but I think the one blowing on the fets helps at higher speeds.
  19. #69
    Charcoal or propane?
    Jan 2005
    Kansas City
    Quote Originally Posted by sabrewolf732
    I second that. I bet there are some ppl on here who don't have the mad soldering skills needed to pull that off, but would be willing to pay up for what must be considered one of the most Xtreme air mods available for a CPU.
    Once again, that is really, really nice. Excellent work.
  20. #70
    Mar 2005
    Ontario, Canada
    From some of the pictures that have been on the net lately i think you will be able to get heatsinks with lots of heatpipes from computer stores soon.
    If most of the heat is transfered right at the center of the cpu the Microchill might work better than I thought.
  21. #71
    Jun 2004
    USA, Vermont
    Not to bad...I made a custom base for my SI-97...if I ever feel the urge to do something like this I would just make a new Cu base for them not solder them...but hey man nice job...maybe once I get my chiller done and my CPU orderd so I have some cach again I will try this by ordering another SI-97...then i will test it and sell it on the forums...cool...
    Dragon
    http://smbach.com/mad.gif
    Opty 175 Rig
    Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
    AM3 Rig
    Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
    DFI NF4 BIOS Guide
  22. #72
    Jun 2004
    USA, Vermont
    Hell send me 2 and I will make a custom Cu base for them...all it will cost you is the cost of the materials to do it...BTW send at least a 12 gram tube of AS5 with the HS as that is what i use instead of solder it seems to work better as it takes a HUGE amount of heat to solder these heatsinks...just drop me a PM if you want something like this done...
    Dragon
    P.S I might not be able to do for a few days because I might be grounded from my grades.. :/ but then again maybe not... just drop me a PM...i will be more then happy to do it for you guys like i said just material costs...
    Opty 175 Rig
    AM3 Rig
    DFI NF4 BIOS Guide
  23. #73
    Jun 2004
    USA, Vermont
    for clarification...the AS5 is used as the tranfer material between the base and heat pipes...and the top is bolted together...no solder and the same/beter temps then solder to boot...
    Opty 175 Rig
    AM3 Rig
    DFI NF4 BIOS Guide
  24. #74
    Mar 2005
    Ontario, Canada
    I think it depends on the amount of tin in the solder as to how much heat it transfers.I also considered a custom base but by keeping the original base lets me mount to any intel clip mount or with the thermalright adapter to any AMD board with no bolts.
  25. #75
    Jun 2004
    USA, Vermont
    Yes but with the bolts and a back plate you can get better pressure on the core with bolts...but with the custom base you could better arrange the heat pipies on ONE base instead of having them stacked so it will have MUCH better thermal tranfer to the heat pipes...and in turn to the sinks...I think that the the copper HS would BE GREAT FOR THIS...as the copper fins would disspaite the heat better...but hey Ford GREAT idea...also can your pressi have the IHS tacken off if so do it you get MUCH better temps with the IHS off then on...
    Dragon
    Opty 175 Rig
    AM3 Rig
    DFI NF4 BIOS Guide
