Ok, I'm going to build a system and was wondering if a P4 2.8B is worth the extra $200 over getting over the P4 2.4?
Thanks, I don't know much about Intel's...I'm an AMD man that is coming over to the "Dark Side"
This is going to go into a Shuttle SB51G
Chassis
Dimension (L)300*(W)200*(H)185 2.85Kg (N.W.) 4.65Kg (G.W.)
Front Panel USB * 2 Line-out/Headphone * 1 MIC * 1 1394 * 1 SPDIF * 1
Back Panel Serial Port * 2 1394 * 2 USB * 2 LAN * 1 Parallel Port * 1(optional)
Extension Bay 5.25" * 1 3.5" * 2
Mainboard FB51
Form Factor Small Form Factor
CPU Socket 478 400/533MHz FSB
Chipsets
North bridge:Intel 845GE South bridge:ICH4
Memory DDR 200/266/333 * 2
VGA Intel 845GE performance 256-bit 3D engine
Audio AC ’97 (supports 5.1 channel) Support Digital SPDIF In/Out
Expansion Slot PCI * 1 AGP * 1
IDE interface ATA-100
Power 200W (PFC)
Accessory TV-Out Support (Option), USB 2.0, Aluminum Chassis
Hot Features Hyper Threading support, Shuttle Form Factor, Shuttle I.C.E. heat-pipe technology
