soltek SL-86SP2+p4C 2.8ghz games crushing*
my friend has that rig,when he runs ut99,CS:s,nba,even mortal kombat 4 ,the BSOD shows up with error message:
that we need to check disk space,he have about 3-4 gig free,and on other partitions has a lot of space,and that we must disable bios shadowing/cacheing,but i didnt find taht option in bios
i install prime95 and runs for an hour and no errors or warnings
interesting is that only ut2k4 runs with no crushing
he reinstall windows a lot of times and the problem is same
so what should i do......
mbo and cpu from title
256 kingmax 400@default latency on 2.7v
4800se 128mb
2x hard disks(40&80gig)
dvd burner
maxpower PSU,s*it but works without undervolt!
- You may not post replies
- You may not edit your posts
Forum Rules
