so yeah title says it, i idle at 31-32 and under prime 95 load it jumps every second from 46-49
this is using mbm
the settings for these temps are in my sig, but here they are anyways
3400+ NC @ 2739mhz (249x11@1.586v)
cpu/ram - 1:1 ratio
OCZ VX (249mhz @ 2-2-8-2)
DFI Lanparty nF3 250GB
Visiontek X800 XT (Platinum Edition+ 525/561)
Maxtor DiamondMax Plus 9 250GB SATA
Antec TrueBlue 480W
Thermalright XP120
Panaflow M1A
all this is in an antec superlanboy with the side panel off, the front 120mm fan stock, and the rear 120mm fan replaced with the same panaflo thats on the cpu, both at max
panaflo specs are 86cfm @ 35.5dba
at first i thought it was cuz of a few scratches on my xp120 and the outer fin of each edge a little bit bent. so i removed everything and bent the two outer fins a bit back to shape, well as close as i could anyways....
afterwards i lapped the xp120 to a mirrored finish (220grit, 320, 400, 1000, 1500)
heres the funny part, i forgot to put thermal paste on after i lapped it! lol...so it was about 2 degrees worst than with thermal paste on load, which means i did a pretty good job
needless to say, i took everything apart and re mounted the hsf with as5 this time, a small dab about the size of a BB in the middle as AS5 suggests
temps are the same as before
i thought maybe the tension off the hsf needs to be increased...so i sanded down the base of the bracket of the xp120 down about .25mm with unchanged results
why am i getting such a high change from idle to load??? why can i only hit 1.586 when i see lots of people claim that they use like...1.65 on stock cooling???
