+ Reply to Thread
Results 1 to 10 of 10
Thread: Memory poll, OCZ or gskill?
    Nov 2004
    Sweden
    0
    Which modules wins this fight? I´m looking for the right modules in my new setup.
    .: MSI K8N Neo2 Platinum - AMD64 3200+ Winchester - R9700Pro - 2*512 pc3200 Ballistix :.
    Jan 2005
    London, UK
    0
    G.Skill LE in my machine
    Does 310Mhz 1T at 2.5-4-3-7 at 2.9v in a DFI nf4 SLI-D
    Xtreme Enthusiast Paxi's Avatar
    Nov 2004
    Europe/Austria
    0
    I would get the G.Skill LE´s for an Amd setup with the Neo2.. TCCD chips dont need much voltage to achieve extreme things.
    System #1:
    i7 975 for bench, W3540 @ 4,4 Ghz HT On, Asus P6X58 Premium, 3x2048 Corsair Dominator 2000CL7, Sapphire 5970 @ stock, Corsair HX1000, 1xOCZ Vertex2 120GB, 3x1TB WD Green
    Cooled by:
    Loop 1: Watercool HK rev 3.0, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
    Loop 2: EK 5970 Nickle, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
    Loop 3: EK Asus NB/SB, Mips Asus Mosfet 1 + 2, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.2 /w Phobya Fans @ 5V Pull
    4,6Ghz (21x220) 1,42Vcore with Single Stage (HT enabled)
    http://img402.imageshack.us/img402/1251/83962063.jpg
    AMD @ testing
    X4 955, Asus Crosshair III, same Rams as on Intel Setup, Sapphire 4870X2 @ Stock, PC Power&Cooling 910W
    Jan 2005
    0
    yes, but UTT perform better and reach better results according to EXTREME LOW LATENCIES AND HIGH FSB
    Xtreme Addict NiCKE^'s Avatar
    Mar 2004
    0
    I would go for GSkill, high clocks, good timnings and low voltage.
    Intel FTW!
    Beanna
    Administrator Jupiler's Avatar
    Jun 2002
    Belgium
    0
    May I ask why you started 2 topics, asking the same question in each of them?
    Rig #1
    Gigabyte P67A-UD4 trying to figure out this POS board
    2600k @ ?????
    2x2Gb GSkill RipJaws-X 1333 (7-7-7-21)
    ATI 5850
    Coba Nitrox 750W
    Watercooled with HK 3.0 CU, Watercool GPU-X³ 5870 Nickel, PA120.3, Laing Ultra with XSPC top
    Rig #2
    DFI UT P35-T2R (0317 bios)
    E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
    2x2Gb Chaintech Apogee GT PC2-8500
    Powercolor 4870
    Corsair 520HX
    Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
    Quote Originally Posted by Movieman View Post
    I've got Supermicro boards that lasted longer than one of my marriages!
    Nov 2004
    Sweden
    0
    wierd , i don´t know how that happend
    Mar 2004
    0
    One got a poll and the other is a dicussion thread?
    Intel FTW!
    Beanna
    Nov 2004
    Sweden
    0
    Someone recommended VX + ddr booster , how well this result on a Asus A8N SLI board? what is max vdimm on that board?
    Registered User Capt MonkeyBoy's Avatar
    Oct 2004
    DeepSouth'UK
    0
    i have the G-Skill 2x256MB 3200/4800, and it rocks..!!!!
    FX55/K8N-Neo2/CorsairXMS3200XLPro/GW7800GS+/4x74GB raptors RAID0
+ Reply to Thread
