Results 1 to 17 of 17
Thread: NF7 mosfet cooling
    Feb 2004
    Croatia
    NF7 mosfet cooling
    http://www.morextech.com/newsite/Pro.../NF7-board.jpg
    this is image of board,high res i supose,so can someone tell me what mosfets should i sink when i do voltmod on mbo?tnx
    Feb 2005
    http://www.madshrimps.com/gotofaqlink.php?linkid=2598
    Go there...pic all the way at the bottom has the hotspots pointed out. I got the Northmole NB cooler from Microcool and it comes with a bunch of little microsinks and whatnot. You can buy them seperately. They are pretty nifty.
    DFI nf4 Ultra-D 704-2bta BIOS
    PREVIOUS SYSTEM
    (3200+ Venice LBBLE 0518APFW @ 2.565GHz - Water Cooled by DangerDen TDX
    1gb PC3200 PDP SYS XBL Ram @ DDR466 2-3-3-6)
    NOW RUNNING/TESTING
    Opty 165 CCBWE 0551WPMW @ 2.7GHz (Still in Testing Stage)
    Thermaltake 560w PSU
    eVGA 6800GT PCI-E 450/1200 - Water Cooled by DangerDen MAZE4
    Self-Modded 2-302 heatercore
    D4 Pump
    Feb 2004
    Croatia
    tnx m8
    I am Xtreme
    Feb 2003
    Netherlands
    Here's what i did back then:
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Apr 2004
    Cornwall/Leeds UK
    http://www.drunken-student.co.uk/pic...nf7_sinks1.JPG
    http://www.drunken-student.co.uk/pic.../nf7_sinks.JPG
    (Pics are too large to post in IMG tags)
    Chips shown in blue rectangles are also sinked.
    .:. X2 @ 2.9 .:. E6600 L628 @ 4.73 .:. AB9 @ 512 FSB .:. E6300 @ 100% OC Stable
    U.K. overclockers: Represent your country, bench for EP-UK! Unite and show the world there IS a U.K. scene!
    Apr 2004
    Helsinki / Finland
    Did some nice benches@3GHz -> 250FSB dual 1:1
    - Team Skootterit
    - SuperPi32M : 18m53.156s with FX-57 / LN2 (Ilkkahy's brazed container)
    - SuperPi8M : 3m55.703s with FX-57 / LN2 (Ilkkahy's brazed container)
    - SuperPi1M : 21.484s with FX-57 / LN2 (Ilkkahy's brazed container)
    Feb 2005
    Damn, those are some impressive sinkage on those mosfets lol. Did you glue that screw to your BIOS chip for easy removal? Great freakin idea if so. lol I use a bent thick paperclip with electrical tape wrapped around it to pry it up out of the corner, but I like your idea better.
    Looks like you also sanded down your NB eh?
    was that 250FSB using 1gb of RAM in DC? because I absolutely cannot hit 250FSB with 1gb, but then again I need to do a voltage mod to get my chipset past 1.7v that might help some.
    PREVIOUS SYSTEM
    NOW RUNNING/TESTING
    D4 Pump
    XIP
    Nov 2004
    NYC
    Heres mine...and this mobo still an oc champ. microcool sinks epoxied with A5 epoxy.
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    Did anybody try replacing the caps for grander ones?
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    c[_]
    Nov 2002
    Alberta, Canada
    you never cooled the driver IC's for the mosfets Dumo, probably lost you some headroom
    All along the watchtower the watchmen watch the eternal return.
    Feb 2005
    lol I have the same microcool chipsinks
    PREVIOUS SYSTEM
    NOW RUNNING/TESTING
    D4 Pump
    Jul 2004
    Germany
    this mosfet coolers rullz
    they are from www.heattrap.de and only for Abit NF7 , Epox 8kra2+
    sry 4 my english
    Apr 2004
    Helsinki / Finland
    Quote Originally Posted by Nubius
    Yep, glue on screw, its easy to hotflash some extra chips
    NB and SB was sanded flat, its helped to gain some FSB
    I used my 2*KHX3000 256mb BH5, did SP1M cas2225 1T CPC ON dual 1:1 266FSB*11.5 MAX Vcore from BIOS
    ..with CO2
    - Team Skootterit
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    STEvil
    You have some specific numbers on how much sinking different parts of NF7 helped you?
    Feb 2004
    Croatia
    nice pic out there!
    c[_]
    Nov 2002
    Alberta, Canada
    Quote Originally Posted by IvanAndreevich
    STEvil
    no specifics since mine didnt even get to run without sinks since I first go it, but I can tell you what i've done to mine and where i'm at for reference plus a few observations.
    nF7 (non -s), Direct VIO mod, heatsinks on mosfets, driver IC's, heatsink on VTT (?) IC (IC just under bottom lever of dimm 3, gets extremely hot and will even be warm with heatsink installed and airflow).
    On the bench:
    0408 2500+M @ 11.5x225.4 2.03v (2592mhz)
    OCZ 600w Powerstream
    SLK-900U + duct + inverted 50cfm 80mm Sunon
    2x512 OCZ PC3200 VX @ 3.2-3.5v
    Ricky tweak
    - 62c max load S&M ~55c load Prime95
    - can run with no cooling over mosfet/driver IC heatsinks for extended periods before they reach 90c.
    In the case (just put it in 15 minutes ago, power outage seems to have done in my a7n8x-dlx 2.0 finally).
    0408 2500+M 11.5x220 1.95v (2520mhz, to make sure its gonna play nice)
    Allied 450w with +5v enhanced (50a 5v/28a 3.3v/18a 12v)
    2x512 OCZ PC3200VX @ 3.45v (? need to measure, different PSU)
    Ricky tweak
    - 48c D2OL load (runs about 1 or 2c less than prime95 i've found)
    - mosfets and driver IC's remain cool so far with just "normal" case airflow (3x 120mm Delta EHE fans @ 5v).
    I'll run some Prime95 and S&M on it later maybe, busy with email and may forget for a while
    EDIT
    Bumped it back up to 11.5x225.4 2.03v and its running stable, 59c max load S&M.
    Feb 2005
    Yeah, I've only had to hotflash once and whew, didn't like any minute of it lol. Gonna have to do that glue on screw trick...freakin nice..can't believe I never thought of that haha
    PREVIOUS SYSTEM
    NOW RUNNING/TESTING
    D4 Pump
