OCN2
Results 1 to 19 of 19
Thread: Quick Mobile XP-2500 Question
    Jan 2005
    Exclamation Quick Mobile XP-2500 Question
    I was under the impression that ALL Mobile Bartons are Multiplyer UNLOCKED,if paired with MoBo with correct Bios options. e.g DFI NF2 ULTRA B.
    My mate just said that new ones need to be modded and they wont run @ 333 never mid 400+!!
    I can't see this at all and can find no info to back him up but want to be sure B4 I shell out on one. My 2500 Barton is UNLOCKED so don't wanna try a Mobile if it MAYBE Locked - (a LOCKED Mobile XP makes NO sense to me tho!!)
    Please can any-one back me/him up on this!!
    If this is true what week no. do I need 2 be able to play??
    Xtreme X.I.P.
    Dec 2003
    Ohio
    pretty sure mobiles are still unlocked... don't see why AMD would bother changing anything else on a K7 when they are about to give them the axe
    Sep 2004
    That would be news to me. That(locking the multi) defeats the purpose as the mobiles lower the multi and vC to save battery life when not needed. Ask him where/who the source of this "info" is.
    Feb 2004
    Croatia
    my friend bought mobile 2800+,yes 2800+,seemes to be that only croatia have them
    its a little confusing,but ok,and he says that mobile 2800+ is locked on 16x multi,and is very bad clocker,he says too that the worst series od bartons goes better that that
    cpu,but all mobiles must be unlocked,seems to be instead 2800+
    Feb 2004
    Croatia
    but can u tell me is it worth to buy mobile when u have unlocked barton?
    Jun 2004
    Florida, USA
    a good mobile is better than a good unlocked regular barton... lower thermal output, lower required voltage.... meaning better OCer... if the new mobiles are bad OCers, then you may be better off staying with the unlocked regular barton
    DFI LP LT X38-T2R
    Intel Core 2 Quad Q9450
    Thermalright Ultra-120 eXtreme
    2x2GB OCZ Reaper DDR2 PC8500
    eVGA 9800 GX2
    WD Raptor X 150GB
    PCP&P 750W Silencer
    CM Stacker 830 SE
    Feb 2004
    Croatia
    but for sure if u want very good mobile u should find mobiles with IQYHA stepping,or one of these IQYHA0352RPMW and IQYHA0401XPMW,may be another better steppings but i dont know them,this is for sure good oc-ers
    Jan 2005
    Cheers 4 all ya responces - I couldn't see that they suddenly decided to lock them either but just wanted to be sure.
    Reason I'm thinking on a mobile is ATM I'm stuck @ 200 FSB - my mate wants a new CPU but isnt bothered bout OC so was gonna swap my Barton for his new Mobile and make use of the volt. and low heat + pionts. So either way I wont loose out any - will check shop and see if they will tell me the steppings of em first tho.
    Feb 2004
    Croatia
    what memory do u have and what mbo?
    Jan 2005
    The 2800+m isnt a true mobile Get a 2400 a 3500 or a 2600
    E6420 @ 8x499 (Clock Gen After That)
    P5K Deluxe (Looking for mods to get me over 530 FSB)
    2x1gig Ballistix 600Mhz @ 5-5-5-10 2T
    Corsair 620hx
    Evga 8800gts 320mb @ 676/1050 Vgpu@ 1.45v Vmem @ 1.9v
    Xtreme X.I.P.
    Nov 2002
    Shipai
    yes, the 2800 is a dtr with full vcore afaik, or 1.60v instead of 1.65v, but by far not the same as the 2600m wich only runs with 1.35v or 1.45v not sure wich of the two, its been a long time
    Feb 2004
    Croatia
    1.45 i but also can run on 1.35,my runs 2300mhz@1.5v
    The un-extreme XIP
    Jul 2004
    get a 35w 2400+, they oc better
    i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
    HD7970@1125/1575 stock voltage
    1TB F1+2*128GB Crucial M4
    Silverstone 450w, no case
    2560*1440@120Hz overclocked catleap
    Steelseries G6v2+5600dpi modded logitech trackball
    Feb 2004
    Croatia
    yeah ,but he must get cpu with good stepping
    Jan 2005
    My Mobo is DFI NFII Ultra B
    Mem is Crucial Ballistix 2 x 512MB PC4000
    Was lookin at 2500 or 2600 mobiles
    Feb 2004
    Croatia
    nice board.ram should be good,get good mobile and clock nice
    Jan 2005
    Cheers 4 ya comments! I've e-mailed store 4 stepping info will see if they respond!
  18. #18
    Feb 2004
    Croatia
    good luck with buying
  19. #19
    Jun 2003
    Portland, OR
    Quote Originally Posted by philter
    I have a mobile 2500 and it is a great cpu. I use one of those zalman 7000 heatsinks to air cool it and it runs at 2500 mhz (12.5x200) 24/7 for the last 6 months. I'm making the switch to AMD 64 and am selling it, but if your still using bartons you can't go wrong with the proc.
    AMD 2500-Mobile (12.5x200) DFI Lanparty Ultra B Rev. A, Geoforce3 ti200, 1 GB Geil UltraX pc4400. Cooling = Zalman CNPS7000A-Cu on cpu, default cooling for vid card and elsewhere. Fortron Blue Storm PSU.
