Dear Customer,
As the manufacture can't guaranteed the chipset supply, I can't
guaranteed whenever, in case you need to RMA your product you will get
the same exact chipset back as the one you ordered. However if such
instance should take place, the memory module manufacture will replace
an equal or better product at time if this instance should take place.
For instances for the PC3500 memory module we had while back since we
are no longer able to replace it, we actually replace it with PC3700 or
PC4000 products. And if the customer has special interest we should be
able to find a special solution for the customer in case the Customer
need to service their product.
The chipset been used is not product specification. The actual product
specification is the specification for the product, taking consideration
for the RMA the product specification is the guild line when we RMA (if
the product is able to go 2-2-2-5 @ 200Mhz the replacement will also go
2-2-2-5 @ 200Mhz.)
Of course this only happens when we ran out of the original solution.
And it shouldn't happen for a long time for as long as the product is in
production or After the reserve solution ran out.
Regards,
Tech support
