I've had my DFI nf4 set up since Monday and it seems a rock solid board @ 200 HTT. All the components in my system apart from graphics card have been tested with a NEO2 so i know they all overclock well, 2500 on processor default voltage and 260 RAM.
When i tried overclocking the DFI it ran into problems strait away, even trying 225 HTT caused problems so i assumed my RAM couldnt cut it on this board. Next i tried 225 HTT with RAM on 166 divider and still i couldnt even get into windows. This was with an LDT of 3. I then tried lowering cpu multi aswell and still no go.
As far as i can see RAM settings wont make a difference as @225 with 166 divider thats 191 and its fine @ 200. Processor is also running under standard so I tried 1.6v chipset voltage, still no go.
This is tested with 201 and 209 bios so im really out of ideas, what could cause this board to overclock so badly when everyone elses is doing so well? All power connectors are plugged in btw and temperatures are all good. CPU = 28, chipset 38 pwm 37.
Thanks for any help, Greatly appreciated!
Dave
