is it safe to add a zalman fanmate or other variable resistor to the 3pin fan power plug on a psu's pcb in order to quiet the fan noise?
i7 980x | corsair dominator 6x4 Gb | TJ07
SLI GTX 580x2 | GT430 | rampage 3 | corsair AX1200
LSI 9265 | OCZ vertex 128x4 raid0 | corsair c300 | hitachi 3tbx3 |
blocks: cpu hk 3.0 | gpu aquacomputer 580x2 | mb ek re3 fc | ram bitspower galaxy
pump: laing d5 x2 | res: koolance 452x2
rad: TC 120.3 120.2 | scythe GTx5
NASs: qnap 879 8x3tb | thecus N5200 2tbx5
As long as its a high watt resistor, should be fine. The only thing that would happen is that the pot would "burn". You would know this by the fan simply stoping to function.
I like my women the way I like my processors...naked.
I am not the HellFire that writes bios files. I work strictly on voltage modifications.
thanks hellfire
