Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: WinXP64bit
    Nov 2004
    Europe/Austria
    WinXP64bit
    Has anybody already tried the the winxp64bit download?, i´m downloading it now.. should be finished in 1h. I will set it up later than on my Seagate 120gb, which is empty at the moment and report about it.
    Report some infos if anybody has already tried it. Maybe there is also an improvement of performance.
    System #1:
    i7 975 for bench, W3540 @ 4,4 Ghz HT On, Asus P6X58 Premium, 3x2048 Corsair Dominator 2000CL7, Sapphire 5970 @ stock, Corsair HX1000, 1xOCZ Vertex2 120GB, 3x1TB WD Green
    Cooled by:
    Loop 1: Watercool HK rev 3.0, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
    Loop 2: EK 5970 Nickle, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
    Loop 3: EK Asus NB/SB, Mips Asus Mosfet 1 + 2, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.2 /w Phobya Fans @ 5V Pull
    4,6Ghz (21x220) 1,42Vcore with Single Stage (HT enabled)
    http://img402.imageshack.us/img402/1251/83962063.jpg
    AMD @ testing
    X4 955, Asus Crosshair III, same Rams as on Intel Setup, Sapphire 4870X2 @ Stock, PC Power&Cooling 910W
    Xtreme Mentor
    Oct 2004
    Cleveland OH USA Bored?: You Know It
    Quote Originally Posted by Bla$nA
    yea ill get it if intel ever switches over to 64bit and takes it mainstream, until then ill stick with good ole xp pro..
    Oct 2004
    SC, USA
    Try and run the latest version of Sandra and let's know how it fairs.
    Core 2 Duo E6600 [L625A] 3330MHz 1.375Vcore 24/7
    Core 2 Duo E6600 [L640F] 3330MHz 1.475Vcore
    Crucial 10th Anv 2 x 1GB DDR2-667 @ 463MHz 4-4-4-12
    ASUS P5B Dlx
    FOTRON BLUE STORM 500W
    TT BT with stock Fan
    Gigabyte Nvidia 7600GSw/ Silent Pipe
    WD Cavier 250GB
    Antec P160
    Xtreme Mentor
    Apr 2004
    CT, USA!!!
    Gonna have my friend burn it later today and give it a shot.
    Nov 2004
    give us a report please!
    thought about installing it but no free space in sight anywhere before I move all my files to my linux server.
    Xtreme Mentor
    Apr 2004
    CT, USA!!!
    Anyone know if this is xp64bit full version or service pack type add on for exisiting xp?
    Nov 2004
    Europe/Austria
    so got some first infos now:
    I have already set it up now. If you have downloaded the file, you have an iso-file. Burn this on a Cd, with Alcohol or Clone Cd. If you got the Cd finished, restart the PC and boot from the Cd. Its like a normal win xp installation. You can only choose the language english. It´s the finished version but it only works for 14 days.. so its a Trial version only to test the programm.
    But i haven´t testet more because now i need to download 64bit drivers @ nvidia.com, you cant install the normal drivers that are for example at the install disk from the Msi Neo2 board. You also need 64bit graphic drivers.
    If i got everything downloaded and installed i will report more and also up some sreens. Because now its like the normal win xp, you can only run in 16 or 32bit, without 64bit drivers.
    System #1:
    Cooled by:
    AMD @ testing
    Nov 2004
    Europe/Austria
    Quote Originally Posted by =[PULSAR]=
    so particular to this question of course its a full winxp64 installation, with a cd like i already said.
    System #1:
    Cooled by:
    AMD @ testing
    Nov 2004
    Europe/Austria
    so.. i installed the 64 bit drivesr now:
    first the nforce driver: 6.25 BETA Win64
    than the graphic driver: 66.96 Win64
    but the systems still runs on 32-Bit, i reinstalled the graphic drivers and the same 32-Bit. Than i installed Sandra the 64bit version. It worked but it looks like the normal 32-Bit Version too. I thought maybe there is an improvement in performance and run 3dmark05 but nothing.. The systems just still runs with 32-Bit.
    Maybe there is an option in bios i have to activate first or i need some more drivers, but at the moment i have no idea. I will informate me about this and maybe set up again or try something else if i know more but maybe its also just better to wait ar the full normal version.
    Anyway: Here are some pics:
Name:	16,32bit Kopie.gif
ID:	24287   Click image for larger version.
Name:	sisoft2 Kopie.gif
ID:	24288   Click image for larger version.
Name:	sisoft Kopie.gif
ID:	24289   Click image for larger version.
Name:	IMG_0147 Kopie.gif
ID:	24290   Click image for larger version.
Name:	light schnapp Kopie.gif
    System #1:
    Cooled by:
    AMD @ testing
    Xtreme Mentor
    Apr 2004
    CT, USA!!!
    From what I have heard its suppose to make a difference in SuperPI runs. See if theres a difference.
    Nov 2004
    Europe/Austria
    k wait a moment but i think if the systems still runs with 32-Bit there is also no differnce.
    System #1:
    Cooled by:
    AMD @ testing
    Nov 2004
    Europe/Austria
    still 35secs...
    System #1:
    Cooled by:
    AMD @ testing
    Nov 2004
    Europe/Austria
    i´ve found a review now @ http://www.gamepc.com/labs/view_cont...amd64xp&page=2.. and it just looks like me by them, it seems like you cant activate 64 bit in the graphic driver menu, i think the only improvement from the 64-Bit version is in games, that support 64-Bit like Stalker. I think also Far Cry supports it so i will install it maybe than and report some more, but i am not sure if farcry really support 64-Bit. Just a suggestion. Maybe somebody knows it 100%?
    System #1:
    Cooled by:
    AMD @ testing
    Banned
    Nov 2004
    so is it worth downloading and running?
    Dec 2002
    royal oak, mi
    Quote Originally Posted by confuzzedintel
    for 14 days... it's for testing, hence the rc-1 status.
    --slly
    Banned
    Nov 2004
    ok i think i might download it and mess with it thanksnow can some one tell me where i can find some beta drivers for Nforce 3 chipset?
    Jul 2002
    No...the reason why the 64 bit video wont work is becasue the DX driver is still now working correctly for ATI and Nvidia beta drivers...
    I just gave the 1289 RC1 a shot a few hours ago also...its starting to get there...loaded up all my drivers except the realtek sound...it did see and install the driver for the realtek GB lan...which normal XP will not pick up untill the driver is installed...
    Also...the latest NF3 drivers do work and do run under 64bit...non beta...but had better performance with the Nvidia beta driver...but only by 2 - 4%...using si sandra...
    Hopefully the DX issue gets worked out very soon...either with a DX update or beta driver fix...then this should be a good OS
    Asus (Native) ROG Rampage Formula
    E6400 ()
    TRU 120 Extreme w/Scythe 120mm 110CFM
    2x1G Ballistix DD2 (D9GMH)
    Sapphire Toxic HD 3870
    Diamomd Viper HD 3850
    600w OCZ GameXstream
  18. #18
    Nov 2004
    Europe/Austria
    jeah i was also told that it depends on the DirectX drivers, i also saw it because if i wanted to install DircectX9.0c, it says that the drivers are not compatible with my system... So we have to wait for the "right" DirectX drivers before it works and then there is maybe also an improvement of perfromance.
    System #1:
    Cooled by:
    AMD @ testing
  19. #19
    Banned
    Nov 2004
    Well i must say it dose kinda suck as when i use the browser it skips : / so i think im going to give windows 2k3 server a try any word on if its better?
    NVM installed beta video drivers skipping stoped
  20. #20
    Xtreme Mentor
    Apr 2004
    CT, USA!!!
    Okay well finally getting around to it I'm installing XP64 now read a couple more reviews on the 3d performance and it looks bad, but 2 days after the review ATI came out with newer drivers hopefully thatyll help. I'll post back with 3dmark comparisons.
  21. #21
    Xtreme Mentor
    Apr 2004
    CT, USA!!!
    Well just got done installing it and loading drivers. My Soundblaster ZS isnt 64 compatible yet...I guess. Screenshot Downloading 3dmark05 now.
  22. #22
    May 2004
    Perth, Western Australia
    looks like the same, i think the differeneces come when your processes support 64bit, then will be a whole lot faster
    a good test would to be wheteher th os is any more of a resource hog or not
    Quote Originally Posted by bh2k
    sorry m, OI'm a bit drunkz!
    Air benches with 3000+, DFI nf3 and 6800GT 2001SE: 26312 3d03: 13028
  23. #23
    Xtreme Mentor
    Apr 2004
    CT, USA!!!
    Wells here the 3dmark03 run I did. 64bit was 377pts lower, the 64bit cpu scores are higher so looks like ATI just needs better 64bit support.
  24. #24
    Xtreme Mentor
    Apr 2004
    CT, USA!!!
    3DMark05, once again looks like 3dmarks suffer but improvement in the cpu score.
  25. #25
    Nov 2004
    Europe/Austria
    weird.. i had not got any improvement in 2k5, but i will just wait for all 64bit drivers now that 64 version really works.
    System #1:
    Cooled by:
    AMD @ testing
