I want to run 29s for superpi 1M. I'm really close. Can anyone recommend A64Tweaker setting to improve my time for corsair 4400C25 running at 10x278MHz?
Dropping the TRTW to 1 brings a signifigant performance boost.
For those of you about to post:
just tried TRTW = 1, PC locked-up. I lowered FSB from 277 to 275 and tried TRTW to 1 again, same results.Originally Posted by craig588
tried maxmem 104 yet?
A64 3400 @ 2700 [270x10] (air)
DFI UT
bh-5 @ 270 A64 Tweaked
9800p @ 480/425
Have a look at the tweaks:
http://www.xtremesystems.org/forums/...ad.php?t=49345
"Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
Can someone please tell me how the select "CAS Laency (TCL)=1.5" in A64tweaker?
I forgot how do you do the max mem 104 again?
(so the boot.ini maxmem tweak (doesn't always help and slows your system down): look in the advanced options of boot.ini, there is "MAXMEM"
in the boot.ini after /fastdetect add /maxmem=104 (or 105)
for example : multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windo ws Server 2003" /fastdetect /maxmem=104
if the option isn't available through msconfig then the boot.ini will do the trick.
In case you're still chasing 29 seconds, try these settings for TCCD:
Good luck.
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
Strange... I hit 29 secs at 325*8,5 - using lame divider
you'll get the same preformance if you do 9x307. your mem was still over ddr600.Originally Posted by 1_2_know
sup3rman... superpi wont show 29sec untill you hit 29.5sec in the process timer window. your still about 6/10ths of a second slow.
Try lowering the latency and read preamble. That should bring about some performance increase.
I'm still trying... but I doubt I'll get there. I think my CPU is only good for 2800MHz.
I'm not sure if 2.5-3-3 timing will make 29s? I have some BH-5 that will do 270Mhz 2-2-2 but that doesn't seem to be enough either.
check my what does trcp and all that stuff thread in xtreme bandwith. That might help you reach 29's.
async with about 255/260mhz ram 2-2-2-5 and htt 310/315 you shoud get 29s @ 2800mhz obviously with a little tweakOriginally Posted by Sup3rman
I got a new Booster, my first one would not go over 3.7
I'm hoping to push my ram a little more to 10 x 275 2-2-2 and see what happens.
I'm thinking I need 10 x 278 2-2-2, or 10 x 285 2.5-3-3, 11 x 255 2-2-2 for 29s.
I going to give the memory 4.0v and hope nothing breaks
