Interesting coincidence there is new Bh-5 coming out now that the new TCCD
are doing so well.
are doing so well.
~ SolTek SL-75FRN2-RL (nForce2) = 10x230fsb, 2.0/2/2/11
~ 1800+ DLT3C/VPMW/0307 ~ Leadtek 6800nu (unlocked 16/6)
~ PCP&C 425deluxe ~ Gskill "LE" 1gb TCCD/437 ~ 36gb Raptor/200gb Barracuda ~ SLK-900a
The MIND is like a parachute - works best when OPEN
considering the loss of performace going from BH-5 to CH-5 (180nm to 130nm), i think DH-5 (110nm) won't give any advantage.
man, cant wait for these modules to hit the stores in belgium !!
are the new twinmoss based on BH5 being mass manufacutred?
No idea. I've seen it on a hard drive. (So, I'm guessing it's not that great)Originally Posted by Nazaar
So, Winbond is back in action? Most interesting.Originally Posted by jjcom
Funny, how my BH-6 can do the same thing. And they're 512 sticks. Edit: just noticed that was 2t. The BH-6 does 275MHz 2-2-2 1tOriginally Posted by El Snorro
I would, but this stupid PSU won't go higher than 3.5v on the +3.3 line . I need to get a new PSU.. A PCP&C510D or something.Originally Posted by Garrett
Sigs are obnoxious.
Do any of you guys have an idea what chips are used on the Twinmos TMII400? Are these UTT as well? If not any comparison of performance?
Really glad Winbond is back in the market
Mobo:Abit AI7/Albatron KX18D Pro II/DFI NFII Infinity/*Chaintech VNF3-250/Abit KG7
CPUs:2.6C@3.2 SLK947U/1700+@2.5 SLK900A/2500+@2.5 ALX800/*A64 s754/1400 T-bird
Vid:ATI 9800Pro/9700Pro/9500np/*9700Pro/PCI VC
Mem:2x256: Corsair 3200LL/Corsair 3500 1x256mb: Samsung PC2100@220fsb(2,3,3,7)/*2x512 Twinmos TMII400
PSU:Sparkle 530/Antec TrueControl 550/*Enermax/Antec 350w
HDD:80gb ATA 133 Maxtor/40gb Maxtor/20GB Seagate/40gb Seagate
3D01:21,092(9800pro)19,956(9700pro)19,186(sm9500np)12,610(GF3ti200)3D03:6,046(sig updated 2/10/05)
looks like Ebay BH-5s will tank.
Asus Rampage Formula X48
Intel Q9650 @ 4.33GHZ
OCZ Platinum DDR2-800
Palit 4870x2
Creative Xi-Fi Extreme Music
Corsair HX1000
LL 343B Case
Thermochill 120.3
2xMCP355
KL 350AT
KL 4870X2 FC WB
DD Chipset Block
Believe it.. This is a 512 stick at 270 with 2-2-2-10 fully A64 Tweaked...Originally Posted by sapphire
A64 3400 @ 2700 [270x10] (air)
DFI UT
bh-5 @ 270 A64 Tweaked
9800p @ 480/425
damn man thats insane! what volts?
I think he is talking about 2*512 dual channel... try get 270 2-2-2 then...Originally Posted by Mag Master 21
if the ram can do it in single, the ram can do it in dual. it all depends on the memory controller if it can still do it in dual.
that's with 3.6vdimm from a 3.72 rail.. I'm hoping to get a booster soon so I can really push herOriginally Posted by enzoR
DFI UT
9800p @ 480/425
BH6/BH5 not doing well in 2x512 is a myth in my opinion... dont know where it started but Ive seen PLENTY of high 2x512 BH6/BH5 clocks
VX/UTT Voltage Scaling, please contribute...
10x260 _ 1T-2-2-2-8-7-15 _ 3.3vDIMM _ 1.75vCORE
Mobile 3400+ CG 0437XDPW
DFI LanParty UT
XP120 w/ 120mm Thermaltake Thunderblade
2x512MB OCZ VX
BBATI 9800np w/Infineon
PC Power & Cooling 510w Deluxe
2*512 all depends on the memory controller...
sounds like AMD will be making controller upgrades soon so this all sounds good to me...
BTW i disagree with what you guys are saying about the processes...
http://www.xtremesystems.org/forums/...ht=BH-5+legend
Originally Posted by saaya
i did some more research on the manufacturing process of the diferent chips, and found this:
[CENTER
according to sayaa BH-5 is 150nm, bh-6 is 166nm, which is why BH-6 can handle REALLY high volts better then BH-5, just ask hipro5 about that one...also, it is my understanding that CH-5 is not the same design as BH-5, as CH-5 was made to be cheaper, explaining why it performed worse then BH at same clocks/timings....
Revv23,
bigtoe himself has said many times BH5=BH6 & CH5=CH6, same die jus different speed bins. Until I see where saaya got his info Im sticking with what bigtoe said.
DFI LanParty UT
2x512MB OCZ VX
ive seen a german site post that info.
3.6v ... thought so. The TCCD should be able to match that at
lower voltages right?
THIS is insane:
"OLD" Corsair BH-5
Previous system:
DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
This was done with Dual channel BH-5 2 x 512MB Twinmos sticks - old school ones - PC3200 at 3.62Volts......Thanks Alex......Originally Posted by Nube
INTEL PWA FOR EVER
Dr. Who my arss...
Maximizer sure seems nice
Very impressive clocks, Hipro!
It sure does........Thanks M8......Originally Posted by SlackeR
INTEL PWA FOR EVER
Dr. Who my arss...
No need to argue, just read up on their respective datasheets from Winbond.Originally Posted by Revv23
From the Winbond 942516CH datasheet (for all speed grades from CH-75 to CH-5), the manufacturing process is described as 0.13um. It also says the 942516CH is sorted into 4 speed grades (-75,-7,-6,-5).
I would be very surprised if Winbond has lines that produce ram using 0.18um, 0.166um, 0.15um & 0.13um in an overlapped timeframe. For starters, it means massive investment wasted, as 0.166 & 0.15 are not necessary as Winbond is already migrating to 0.13 at the time when the BH series was in production. The incremental benefits offered by 0.166 & 0.15 over 0.18 does not justify the investment needed. Secondly, why would Winbond waste production cost in producing chips in a larger process when a smaller & more cost effective process is available (not to mention the cost in inventory controls)? Thirdly, what happens to those CH-5 that cannot function at 200MHz but can do so at 166MHz?? Do they junk them altogether?? They surely can't be called CH-6 if it's from a different process!!!
The words AH, BH, CH tells u which generaation it belongs, & the -75, -7, -6, -5 tells u it's speed. If u look at the ICs themselves, it's printed "BH-5" or "CH-5", BH5 or CH5 is just an abbreviation.
http://www.winbond.com.tw/c-winbondh...2_g_1_a.htm#06
Datasheet for CH series available at bottom of the page.
Yea with 2.5-3-3-7 timings not those nice 2-2-2-x timings.Originally Posted by Susquehannock
Thank you clarenceOriginally Posted by clarence
DFI LanParty UT
2x512MB OCZ VX
